Light bar install. - Mustang Evolution
Old 07-23-2016, 07:36 PM   #1
Light bar install.
Hey guys. I remember this topic being posted before but couldn't find it. I recently bough a 22 inch light bar from swlights and am excited to get installing. Anyone one done this before? Have a great mounting point, looking for any wiring advice. ThanksClick image for larger version
Name:	ImageUploadedByMustang Evolution1469320545.538406.jpg
wawanesa5speed is offline   Reply With Quote
Old 07-24-2016, 03:36 PM   #2
salsa04GT's Avatar
This is just my opinion but I kind of like it in a weird way. I don't know what application or situation you would use this, but at a car show would make it stand out. I'm sure it's not for everyone, but me personally I like the idea. If you go for it let us know how it turns out.
salsa04GT is offline   Reply With Quote
Old 07-24-2016, 06:55 PM   #3
I would definitely be interested in this. I do a lot of driving on some dark country roads. This would light up the road a little bit more.
Sent from my iPhone using Mustang Evolutio
Alewan_02_GT is offline   Reply With Quote
Old 07-24-2016, 08:07 PM   #4
Yeah I gave the bar a test and HOLY **** is it bright. Like 3x my high beams. I'm sure it won't be as effective mounted in the bumper, but bright non the less
Old 07-24-2016, 08:29 PM   #5
I wonder how hard it'd be to wire it to the fog light switch.
Old 07-25-2016, 12:04 AM   #6
Revvv's Avatar
Not hard as long as you have the correct relays and resistors.
Old 07-25-2016, 01:02 AM   #7
Joshy's Avatar
I think that looks pretty awesome. I would like to install one in the open area of my trucks bumper. Pretty cool on the mustang.
www.petom.biz
Joshy is offline   Reply With Quote
Old 07-25-2016, 01:05 AM   #8
Revvv's Avatar
I was going to put one behind the grill of my Dodge Ram before the engine puked.
Old 07-25-2016, 06:45 AM   #9
Torino's Avatar
There should be a connector behind your bumper for stock fog light installs so you can use splicer connectors to tap into that or see if you can get the connecting ends from Ford or a junk yard and have an OEM type set up! Your lights should have 2 or 3 wires right?
Sent from my SM-G7102 using Mustang Evolution mobile app
Torino is offline   Reply With Quote
Old 07-25-2016, 07:36 AM   #10
I have never looked at the fog lights. I hardly use them so I'd have to look and see about the wiring.
Old 07-27-2016, 11:56 AM   #11
Lorraine's driver
ab_mach1's Avatar
Shouldn't need any resistors unless it will be connected to your turn signal relay. If you connect it to the fog light switch, it should be fine. That is, assuming it does not exceed the wiring capacity. If you are wanting to wire it separate and want it controlled by it's own switch, just make sure you buy a standard type relay, not a flasher relay. I'm not sure about all flasher relays, but most are built to flash rapidly when the resistance is low, basically so you know when a bulb is burnt out. This is why so many people need to add resistors to LED lighting on cars with incandescent lighting. The easier way to handle that is to buy an LED flasher relay (no resistance relay) to replace the factory flasher relay. Then you won't need to cut wires and add resistors that get hot.
Instagram: @ab_mach1
Light bar install 13stang901 2011-2014 V6 Mustang 0 11-04-2012 05:44 PM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 07:37 PM
/bar/ Vs. /the-Bar/ 03redfire cobra The Bar 5 11-09-2005 10:35 AM
How to: Roll Bar (light bar install) cagedthought Mustang Audio & Video 12 11-02-2004 09:18 AM
Reccomendation: Do NOT install a Light Bar mexor The Bar 3 07-24-2004 10:52 AM
06:23 PM
