Wheel question - Mustang Evolution
Old 07-24-2016, 12:30 PM   #1
Wheel question
Hello everyone, I recently put a cat back exhaust on my car (SLP Loutdmouth). I'm pretty sure the new pipes are wider than the stock ones and I'm looking to get a set of staggered wheels for the car, my only concern was that the 10.5" wide wheels and tires in the back would rub the exhaust because there's not much room under the car, does anyone have a setup like this or know if I'd have enough clearance?
SN95_96 is offline   Reply With Quote
Old 07-24-2016, 12:42 PM   #2
phillip433's Avatar
If there's no clearance then get a small spacer
phillip433 is offline   Reply With Quote
Old 07-24-2016, 01:15 PM   #3
+1 on the spacer. I have mmd black kage wheels for my car. The fit was close, a mm or two between the tire and exhaust. Happen to have a 1 inch spacer lying around and that did the trick. Really stuck the wheels out too which worked for me.
wawanesa5speed is offline   Reply With Quote
Old 07-24-2016, 02:35 PM   #4
I thought about getting spacers but I've heard so many bad things about them, have you ever had problems with them?
Old 07-24-2016, 07:38 PM   #5
Speed_Mister's Avatar
Region: Arkansas
I had 1.5" spacers on before and the wheels come off the car while u-turning. I wouldn't run a spacer any bigger than 1/2" on the rear or just get the correct back spacing you want. Make sure you can twist the lug nuts at least 6-6.5 full turns torquing down lug nuts to spec using star pattern on the studs you should be okay.
2004 Mustang Gt
5 speed manual
Full bolt ons
Built moser rearend
395rwhp 500rwtq
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 07-24-2016, 08:16 PM   #6
TheJigShow's Avatar
I've had a 2004 GT before with H&R Springs (lowered 1.5"), 10.5" wide wheels with 315 tires, and the SLP Catback and I had no rubbing issues between the wheels and catback, let alone running anything else period, short of just rolling the fenders
"Jig"
2014 Ford Focus ST (ST3, Tuxedo Black Metallic)
1997 Ford Mustang GT (Rio Red)
"Jig"
1997 Ford Mustang GT (Rio Red) (RMR #7832)
2003 Ford Mustang GT Centennial Edition (Black) (SOLD)
2004 Ford Mustang GT (Redfire) (SOLD)
1985 Chevrolet C10 Custom Deluxe (Red) (SOLD)
TheJigShow is offline   Reply With Quote
For Sale: Vossen CV3 rear wheel/tire and Front wheel/tire, OEM clutch and Flywheel jamyzd30 Mustang Parts for Sale and Wanted 4 03-23-2017 09:28 PM
Wheel gap question and lca question Mdazi 2011-2014 Mustang GT 27 05-27-2013 07:11 PM
Wheel is off center in wheel well. S197stanGT 2005-2010 Mustang GT 9 03-04-2013 02:55 AM
Wheel Question / possibly stupid question Rogue Slider Mustang Wheels & Tires 8 05-29-2012 12:21 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
02:06 PM
