Misfire Issue After1997 GT Coolant Hose Failure; Need Help Solving - Mustang Evolution
Old 07-24-2016, 07:01 PM   #1
TheJigShow's Avatar
A couple days ago the one heater hose on my 1997 Mustang GT starts on the passenger side of the intake manifold and goes right into the firewall) burst open, getting coolant basically everywhere. After replacing the hose and cleaning everything off, the car started up fine and even drove like new for about five minutes. From then on, it was misfiring horribly, making it barely able to move at all. The next day, the same thing: started and ran fine, only to misfire horribly after a few minutes and not go away.
Both times the code P0354 popped up, saying "Ignition Coil D Primary/Secondary Circuit Malfunction," so I went through the steps to not only blow out the spark plug valleys and clean everything, but I then replaced all 8 spark plugs, ignition wires, and both ignition coils. Fired it up, and it made no difference whatsoever; still misfiring horribly.
What do I do from here? I'm not sure where to go next, as I've replace all ignition parts (considering the engine code was for ignition). Any help would be hugely appreciated!!
"Jig"
2014 Ford Focus ST (ST3, Tuxedo Black Metallic)
1997 Ford Mustang GT (Rio Red)
"Jig"
1997 Ford Mustang GT (Rio Red) (RMR #7832)
2003 Ford Mustang GT Centennial Edition (Black) (SOLD)
2004 Ford Mustang GT (Redfire) (SOLD)
1985 Chevrolet C10 Custom Deluxe (Red) (SOLD)
TheJigShow is offline   Reply With Quote
Old 07-25-2016, 10:22 AM   #2
TheJigShow's Avatar
Bump
"Jig"
"Jig"
Old 07-25-2016, 12:33 PM   #3
It sounds like the number 4 coil has failed. That is the cylinder closest to the firewall, on the passenger side of the engine.
What likely happened is, the spark plug well filled with coolant and it shorted out the coil, which then overheated and failed.
Old 07-25-2016, 12:54 PM   #4
TheJigShow's Avatar
Since this started, I've cleaned & blown out the spark plug wells, replaced all 8 plugs, wires, and both ignition coils (in that order) and it didn't solve anything. There's no coolant leaks anymore and the car hasn't been out in the rain. So that's where I'm stuck 😐
"Jig"
"Jig"
Old 07-25-2016, 01:32 PM   #5
Sorry. Wasn't paying attention to the year of your car..
Hmmm. I suppose that you could try swapping the #4 fuel injector with #3 and see if you get a P0353 code. If that doesnt change anything, there could be a problem with the signal that the coil is recieving from the computer.
Old 07-25-2016, 09:35 PM   #6
TheJigShow's Avatar
I'll give that a shot when I get the chance. If it's not the injector, how do I deal with the computer to coil signal problem?
"Jig"
"Jig"
Old 07-26-2016, 10:31 AM   #7
Since the coolant sprayed everywhere, you might start with checking all of the electrical connections related to the ignition system and the PCM. Make sure that everything is dry and corrosion free.
Old 07-29-2016, 07:50 AM   #8
TheJigShow's Avatar
SOLVED!! Turns out the plug to the driver side ignition coil was being pulled too tight so it strained the one side of it, causing it to act funny. It threw the P0354 code, but after hooking up the scanner, the graph should cylinders 2 & 8 acting funky, which was coming from that coil. I gave the wires some slack and made sure everything was good and the car has been purring since 😁
"Jig"
"Jig"
thought my gt was on fire but a certain coolant hose blew out gt_nez 1996-2004 Mustang GT 17 03-08-2015 11:40 PM
07 V6 Lower Coolant Hose Issues AJShiftSoerens 2005-2010 V6 Mustang 1 12-30-2014 04:54 AM
Coolant hose 2013 Jmusc16 2011-2014 V6 Mustang 1 04-12-2013 06:18 PM
Track tonight solving grudges 04machazblue 1996-2004 Mustang GT 43 06-18-2011 12:17 PM
what coolant hose is this? jimmy_beaner 1996-2004 Mustang GT 53 02-14-2009 10:13 PM
10:13 PM
