Fuel pressure - Mustang Evolution
Old 07-28-2016, 09:56 PM   #1
Jay180's Avatar
Fuel pressure
What is the fuel pressure suppose to be at during idle and at wot- or just being driven? Click image for larger version
Name:	ImageUploadedByMustang Evolution1469760934.361848.jpg
ID:	203845 this is with the key turned
Name:	ImageUploadedByMustang Evolution1469760954.774074.jpg
ID:	203846 this is when it is on and at wot
Jay180 is offline   Reply With Quote
Old 07-28-2016, 10:01 PM   #2
Mile high JDF's Avatar
My car is usually running low 30s at idle and WOT goes to low/mid 50s
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-28-2016, 10:19 PM   #3
Speed_Mister's Avatar
Region: Arkansas
Mines usually around 30-35psi idling and more around 35-40 during normal driving. I never watch it during full throttle to busy watching other stuff. Lol.
2004 Mustang Gt
5 speed manual
Full bolt ons
Built moser rearend
395rwhp 500rwtq
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 07-28-2016, 10:21 PM   #4
Jay180's Avatar
I just changed out my fuel pump, what do you think it is?
Old 07-28-2016, 11:14 PM   #5
Fuel pressure at idle should be 40-70 psi.
The fuel system should hold pressure for five minutes with less than 5 psi loss from indicated operating pressure.
I'm not sure that there is a specification for WOT. I don't see one in my manual anyways.
Old 07-28-2016, 11:34 PM   #6
Jay180's Avatar
So what could be causing my idle to be lower than normal? Dirty injectors? Clogged filter?
Old 07-28-2016, 11:44 PM   #7
Disconnect the IAC and see if there is any difference in the idle.
Old 07-28-2016, 11:48 PM   #8
And definitely change the fuel filter if you haven't already done so.
That should be done as a matter of course when replacing the fuel pump.
Old 08-02-2016, 11:42 PM   #9
Jay180's Avatar
So switched out the filter. It runs great 70% of the time but sometimes still turns off. what do you guys think? I'm going to check my pressure again tomorrow.
Old 08-03-2016, 12:01 AM   #10
Region: Arkansas
Maybe bad gas? Or dirt clogged up at the injectors.. Best to see what the pressure is doing. Could be the fuel pump. I've seen brand new good brand name parts fail many times!
2004 Mustang Gt
5 speed manual
Full bolt ons
Built moser rearend
395rwhp 500rwtq
Full Bolt Ons
370rwhp 470rwtq
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 04:32 PM
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 04:15 PM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 06:03 PM
Fuel pressure guage questions eagle05 1979-1995 Mustang GT 4 10-25-2006 05:47 AM
No schrader valve on 05s for wet N2O or Fuel Pressure guage justin00stang 1996-2004 Mustang GT 1 11-17-2005 09:08 AM
11:43 AM
