Best Cam for PI Swap on NPI Short Block - Mustang Evolution
Old 07-29-2016, 09:04 AM   #1
TheJigShow's Avatar
The title pretty much sums up the question lol. I'm looking now to do a PI swap on my 1997 GT, and I want to know what's the best cam I can run without getting any piston-to-valve clearance issues. I'm aware with that setup, the PTV isn't very high, but I've been seeing different answers, from "don't run anything but stock," to only stage 1, to even someone saying Hitech Stage 2 cams. Which is the real best? Also, I'm going to be adding a nitrous shot so I have to consider that as well
"Jig"
2014 Ford Focus ST (ST3, Tuxedo Black Metallic)
1997 Ford Mustang GT (Rio Red)
"Jig"
1997 Ford Mustang GT (Rio Red) (RMR #7832)
2003 Ford Mustang GT Centennial Edition (Black) (SOLD)
2004 Ford Mustang GT (Redfire) (SOLD)
1985 Chevrolet C10 Custom Deluxe (Red) (SOLD)
TheJigShow is offline   Reply With Quote
Old 07-29-2016, 09:09 AM   #2
Member
Well if the block is out of the car you may be able to have the pistons cut for larger valve reliefs.
Sent from my 0PJA2 using Tapatalk
sigmanx is offline   Reply With Quote
Old 07-29-2016, 10:41 AM   #3
TheJigShow's Avatar
Yup, the block will be out of my car. Would cutting the Pistons for the clearance lower the compression ratio?
"Jig"
"Jig"
Old 07-29-2016, 11:59 AM   #4
Member
Very Slightly but not enough to really make any difference.
Old 07-29-2016, 02:55 PM   #5
TheJigShow's Avatar
Well that sounds promising then. For the sake of argument and curiosity, if I don't notch the Pistons, what's the option then for cams?
"Jig"
"Jig"
Old 07-29-2016, 03:06 PM   #6
Member
Given that the pistons won't have as much of a dish and the valve is still located in the same location you would still have the normal ptv issues and possibly more with a npi block. I honestly don't know I would go more than stage 1 with a proper degree job.
Old 07-29-2016, 04:47 PM   #7
Comp Cam xe268ah, or CMS "stage 2" are your best bet. The dish doesn't matter at all since the clearance issue is at the edges. You would have the same clearance with stock pistons and flat tops.
Old 07-29-2016, 04:48 PM   #8
Member
Yes that is possible with the piston notch.
Old 07-29-2016, 04:49 PM   #9
Properly set up 268s or CMS stage 2s won't need valve reliefs. It is extremely tight, but its been done.
Old 07-29-2016, 04:51 PM   #10
Member
Ya I'm sure it's doable with someone who really knows their stuff but I'm a what if type of person!
Old 07-29-2016, 07:23 PM   #11
Slater2111's Avatar
Notch the Pistons while its out. Then throw some CMS stage 2 cams in there and call it good. Or you can get a set of clearanced stock valves and do it that way. The later might be cheaper.
2003 GT: JLT CAI, summit 75mm TB, C&L plenum, 24# injectors, Mac Prochamber, SLP LM1 cat back, 3.73 Gears, FR500 Diff, FR500 diff cover, Jmod trans and shift kit, Max Motorsports subframes, Koni oranges front and rear, DBA discs front and rear, shrader performance rear seat delete, APSX D2 wideband, MPT happy customer.
Slater2111 is offline   Reply With Quote
Old 07-29-2016, 10:48 PM   #12
Member
Swapping for clearance valves also allows for a valve job on the head as well since its out.
Old 07-30-2016, 01:20 AM   #13
I have the hitech stage 2's in my 01 gt, been in there for 40,000 miles now and I love them. They work well with boost too, my car is procharged.
01silverGt is offline   Reply With Quote
Old 07-30-2016, 04:53 PM   #14
TheJigShow's Avatar
Well these all sound like good ideas. I'm not sure I want to mess with the Pistons. If I were, I think i would just go to extra mile to get better Pistons, and at that point I would just get forged internals. If Hitech stage II work without any piston modding I'm set on that
"Jig"
"Jig"
Old 07-30-2016, 04:56 PM   #15
Member
If your not interested in pistons or notching them since you have it out anyway I would at least do the modded valves so you don't have to worry about any ptv issues especially since your doing cams anyway and it's not much more work on top of what your having done.
Old 07-30-2016, 05:00 PM   #16
TheJigShow's Avatar
The valve job I can do. Something about notching the Pistons seems off to me, only because I feel as if something would just get screwed up in the end and destroy stuff, knowing my luck
"Jig"
"Jig"
Old 07-30-2016, 05:01 PM   #17
Member
Sounds like a plan to me! I want cams too but it will be a while before that happens!
Old 07-31-2016, 02:17 PM   #18
"Jig"
My motor has never been opened up other than installing the cams. I didn't even change valve springs with the hi tech stage 2's. Threw a blower on at 100k and it now has 122k on it and shows no signs of engine wear, been making 430 to the wheels for 5 years.
best cams for 96-98 npi's? 98GTCONV 1996-2004 Mustang GT 9 01-03-2013 07:09 PM
Thinking about MHS NPI stage 1or 2 cams for my NPI heads. leviz79 1996-2004 Mustang GT 1 09-12-2012 01:58 AM
4.6 npi block with pi heads Rexxx73 1996-2004 Mustang GT 4 07-06-2012 10:11 PM
4.6 npi block with pi heads Rexxx73 New Member Introductions & Greetings 0 07-06-2012 01:22 PM
best place for a short/long block? GUDNEVL 1979-1995 Mustang GT 7 01-29-2011 02:02 PM
10:07 PM
