Power steering leak - Mustang Evolution
Old 08-01-2016, 02:47 PM   #1
bkh1994's Avatar
Power steering leak
I have a 2002 Mustang GT. I have a power steering leak. It isn't a very bad leak. I have to top it off once a week, uses about a quart a month. From looking under the car, the only place I can find that could be a leak is where the steering shaft connects to the rack. I do not have the rubber (plastic?) piece that I highlighted in the pictures. The fluid pools up in that spot and drips/runs down. That is the only spot I have been able to find a leak at. I can't seem to find this part or even the name of it anywhere. I am assuming that is the culprit.
I have filled it with power steering fluid, automatic transmission fluid, and also used No Leak power steering stop leak. The No Leak drastically cut down the fluid loss but I guess it has ran through now and the leak is back to how it was before.
Thanks!
ID:	203915   Click image for larger version
bkh1994 is offline   Reply With Quote
Old 08-01-2016, 02:52 PM   #2
Gravydog316's Avatar
I just had a leak from my power steering pump(...?) maybe(?)
Sent from my iPad using iOS X beta 2
Old 08-01-2016, 02:55 PM   #3
bkh1994's Avatar
It could be, that's why I am asking.
My power steering pump doesn't whine at all. It has whined once or twice before but that's because it was low on fluid caused by the leak. The steering wheel isn't very stiff or shaky
Old 08-01-2016, 05:31 PM   #4
I never had any issues that i noticed, like stiff steering or anything; mine had always had really quick, responsive steering.
When I went to get my airbag recall done, I found out about it.
I dunno how long my pump was leaking tho.
Old 08-01-2016, 08:05 PM   #5
Both of you should clean up the power steering fluid mess with some Simple Green so that you can determine exactly where the leak is coming from.
If your steering rack is the source, OP, you will likely need to replace the rack.
Old 08-01-2016, 08:38 PM   #6
jeno's Avatar
Thanks!
More than likely it has deteriorated don't think you can get that part looks like time for a new steering rack
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Power Steering Leak thump 1996-2004 Mustang GT 7 04-24-2016 04:16 PM
Power Steering Fluid Leak JimmyMosqueda Pre-2005 V6 Mustang 6 05-12-2014 12:36 AM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 07:31 PM
1973 Mustang Power steering box leak? What needs to be done? kang29 Classic Mustangs 3 12-14-2011 10:38 AM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-28-2008 12:54 AM
10:31 PM
