2000 gt will not go into overdrive, please help! - Mustang Evolution
Old 08-05-2016, 04:47 PM   #1
crystal0406's Avatar
I have a 2000 mustang gt, when I start it in the morning, it will act like it wants to die. Battery is new, alternator and starter are fairly new. The engine was replaced and it has 80,000 miles on it. The tranny was rebuilt, and the rear end gears were replaced with bigger 4:10 gears. Tires are 18's. So the speedometer is off, but my O/D light is blinking too, it also revs up when I get up to 70n mph and will not go into overdrive. I have replaced the IAC valve myself and that has helped the idling. It feels like its not getting enough air. I also have an O2 sensor that needs to be replaced and will replace that soon. And when I get out on the highway to go to work in the morning it will bog down and act like its going to die, let off of the gas and put foot back on to gas and its fine. It only does this when it hasn't been started for a few hours. Help?
crystal0406 is offline   Reply With Quote
Old 08-05-2016, 05:17 PM   #2
Jbone007's Avatar
Ouch you are having a lot of issues, but they all could be related to the blinking OD light which is kind of like check engine light but for the transmission. Check out this link it talks about the flashing OD light in general terms. Hope it helps!
O/D Off Light Flashing On and Off – Transmission Repair Cost Guide
Jbone007 is offline   Reply With Quote
Old 08-05-2016, 05:47 PM   #3
Thank you very much!
Old 08-06-2016, 12:55 PM   #4
A reputable transmission shop will be able to diagnose the cause of the flashing overdrive light.
Loud noise and vibration when car shifts into overdrive gear Iryan7 Pre-2005 V6 Mustang 1 10-15-2015 10:08 PM
Help. Overdrive flashing serviced for Solenoid Fiveoh14CS 2005-2010 Mustang GT 1 02-13-2014 09:52 AM
HELP PLEASE!!! 2000 Mustang GT won't go into gear with car on!?! WICKED STANG 83 1996-2004 Mustang GT 22 10-18-2012 06:24 PM
Turning of Overdrive, does it go into “Performance Mode”? Renegade 800 Pre-2005 V6 Mustang 13 06-27-2008 06:58 PM
Question about Overdrive light Twitch Pre-2005 V6 Mustang 6 02-11-2004 05:05 PM
03:56 AM
