2001 Cobra Block - Mustang Evolution
Old 08-17-2016, 02:46 PM   #1
BeastyStang's Avatar
2001 Cobra Block
Hey you guys. I have a question! I found a 2001 Cobra block (teksid) for cheap online. My question is it worth buying? I'm planning on building my car with the Tork Tech set up. I already have a few things purchased. Any info would be greatly appreciated. Thanks!
BeastyStang is offline   Reply With Quote
Old 08-17-2016, 09:33 PM   #2
2001 Cobra engine is a WAP block, not a Teksid. It is still a good block though.
How much are they asking for it?
And what are the condition of the cylinders like?
Old 08-18-2016, 11:30 AM   #3
The seller was real adamant about it being a Teskid. I found another seller claiming the same. But it's a good thing i brought the question up.
For my goals, is this worth the purchase? I will be posting up pics. Click image for larger version
Name:	ImageUploadedByMustang Evolution1471541383.897104.jpg
ID:	204293Click image for larger version
Name:	ImageUploadedByMustang Evolution1471541402.784777.jpg
ID:	204294Click image for larger version
Name:	ImageUploadedByMustang Evolution1471541428.499180.jpg
Old 08-18-2016, 02:08 PM   #4
The block in the picture that you posted is a Teksid. You want to find one that is still at the standard bore size. The engine that is at .020 over, is in need of a complete re-sleeve, in my opinion.
The Teksids are considered to be the strongest aluminum production blocks. So it will suit your needs, whatever your current or future goals may be.
Old 08-18-2016, 04:25 PM   #5
Now say i end up getting the block, is everything transferable? As in all my internals, heads, manifold compatible with the block? I do plan on upgrading most of all those parts.
Old 08-18-2016, 07:49 PM   #6
If I remember correctly, the only thing that is different on the Teksid blocks is the oil pump pickup tube. Everything else bolts right up.
If you go this route, you should purchase Sean Hyland's book about building modular engines.
Old 08-18-2016, 08:32 PM   #7
Well I appreciate you sharing your knowledge with me. I plan on going for it. I have quite a few parts for my build.
Old 08-18-2016, 09:17 PM   #8
I know this is a whole new topic. Would I benefit from putting on the 39lb injectors with a new fuel pump? Or would it be harmful. On a stock engine. Just out of curiosity
Old 08-18-2016, 09:24 PM   #9
It wouldn't be harmful... Nor, would you see much of a benefit from them.
You will need a new tune that takes into account for the higher flowing injectors.
Old 08-18-2016, 10:49 PM   #10
Mile high JDF's Avatar
Would you be sleeving it or staying .020" over?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-19-2016, 10:27 AM   #11
What would you recommend? I am still learning about all this.
Old 08-19-2016, 10:30 AM   #12
What would you recommend? I am still learning.
---------- Post added at 04:30 PM ---------- Previous post was at 04:29 PM ----------
Sorry for the double response lol. My phone said it didn't post the reply.
Old 08-19-2016, 11:04 AM   #13
Lorraine's driver
ab_mach1's Avatar
^Yup. 99 and earlier 4 valve 4.6L's were Teksid blocks.
Instagram: @ab_mach1
Old 08-19-2016, 12:31 PM   #14
The pic with the block is from an 01' so that's a WAP? If so, is it worth buying?
Old 08-19-2016, 12:58 PM   #15
Lorraine's driver
ab_mach1's Avatar
I wouldn't buy it because if he's showing a Teksid block, but claiming it's an 01 block, he's wrong. That's a red flag. Probably means he doesn't have all the correct info on what he's selling. Or, he could be showing a Teskid block knowing it's a WAP and trying to take someone. Either way, not someone I'd buy from lol.
As far as WAP blocks bored over..I wouldn't buy one because they aren't all that thick to begin with so I would rather start with one un-bored. That way you know it's done right and you can obtain all the proper sleeves etc. specifically for your block.
Instagram - @ab_mach1
Old 08-19-2016, 01:34 PM   #16
Not sure why those engines are being advertised as 01's. I suppose that it is entirely possible that the original engines were replaced with Teksid blocks. However, in one of the ads, the part number that is posted is NOT for a Teksid.
.020 is considered by many to be the maximum safe over-size for the cylinders on a Teksid. That is why I recommended trying to find a block that is at the standard cylinder size. The cylinders can be sleeved, but it will cost more than finding a block that is in good shape to begin with.
Old 08-20-2016, 03:23 AM   #17
99GT4.6's Avatar
I heard in the past a few early 01 Cobras did come with Teksid blocks in them from the factory.
99GT4.6 is offline   Reply With Quote
Old 08-20-2016, 08:58 AM   #18
That is a possibility. If I recall, some of the early 01 model year GT's came equipped with T45 transmissions rather than 3650's. Ford is well known for using up all of their obsolete parts if possible.
2001 Cobra block Jessiecorona03 SVT Mustang 0 05-31-2016 02:49 PM
Small block big block discussion @ work ReggStang 2005-2010 Mustang GT 6 07-15-2012 03:16 PM
2001 SVT Cobra :: 2001 Ford SVT Cobra 98StangKid Member Garages 0 06-22-2012 03:49 PM
small block/ long block blackGT91 1979-1995 Mustang GT 15 05-14-2012 09:21 PM
5.0 block vs 4.6 block 98RedGT 1996-2004 Mustang GT 4 06-13-2011 12:03 PM
12:51 AM
