Erratic shifting - Mustang Evolution
Old 08-20-2016, 07:14 AM   #1
Erratic shifting
So I've finally gotten over a year of misfiring and contemplation of a motor swap to find out I could've fixed my issue by simply replacing all the coil on plugs.. I did and it runs great.. That's after a battery, alternator, four 02 sensors, egr valve Dpfe sensor, fuel pump and filter, injector cleaning (used a battery syringe and brake cleaner) new intake manifold, ect sensor, cam/crank position sensor... I just didn't think it was a cop. It was
So now I'm driving it around and it has a shift kit and a rebuilt trans. So I often use the o/d off button to downshift .. And I noticed once I got through 3rd gear and hit the button to let it shift up to o/d.. It never did. Once I hit a stop sign and it started back off in 1st it ran through the gears all the way into o/d like it should.. But then randomly at abt 60 it dropped out of o/d without any whatsoever change to throttle position .. And I think it went all the way to 2nd because it revved hard but just for a split second before it settled right back in o/d... When I was coming to a stop to pull in my driveway it jumped back and forth a little
Then when I drove it again an hour later it was fine! When I first got the car I pointlessly replaced the 3 solenoids .. That's when I learned it was rebuilt. And I think they may have been from ebay.. I'm hoping I can find the ones I took out.. :-/
Any input ?? Oh and the fluid looks brand new
Chrishart749 is offline   Reply With Quote
Old 08-20-2016, 05:30 PM   #2
Switched all three solenoids in the transmission back to old ones which are labeled ford and the new ones were not
All is well
Old 08-20-2016, 07:15 PM   #3
Every good transmission technician that I have ever spoke with has always insisted on using factory replacement parts, as far as the electronics go.
Old 08-21-2016, 01:13 AM   #4
Mfore33's Avatar
Is it difficult to change the solenoids? I am getting late shift 2 to 3 code on my 2000 gt auto.
Old 09-04-2016, 05:44 PM   #5
its not too bad
drop the pan and you can see all 3 of them.
Old 09-08-2016, 02:53 PM   #6
Okay guys.. I was wrong and am hoping someone knows a little more abt this whole thing. After a few times driving the car since replacing the solenoids.. Last night it gave me problems again. What happened: I pulled off from a stop sign and it didn't want to shift from 3rd into overdrive. It didn't just rev freely like a miss.. No instead it just hung in third. It stayed there a bit and then finally caught o/d abt thirty seconds late! And then momentarily later when it just dropped overdrive like a bad habit .. Motor revs like it would with a downshift etc.. So I just let off and everything seemed fine from there on. I was only a couple minutes from home. No lights no codes no flashing o/d fluid level is correct color is good doesn't smell burnt. Fluid is new.
So I know ..(not from personal experience) the trans can be electronically affected by numerous sensors
The mlps aka trans range sensor aka neautral safety switch..
The vehicle speed sensor
Throttle position sensor
Mass air flow sensor
And then all the shift solenoids but .. Those are likely not the cause because the symtpoms still exist from one set of said solenoids to the other.
Any input would be awesome
Does this sound like internals ****tin out on me? Or a dumb sensor?
I could just buy all above mentioned parts and change them but I felt compelled to ask questions first.
Also thought it would be worth mentioning that otherwise every shift is firm snappy extremely clean and satisfying.
Power Shifting vs Quick Shifting BlueDemon 2011-2014 Mustang GT 10 06-02-2016 09:50 AM
V6/ 6spd ERRATIC VIBRATION Toydos 2011-2014 V6 Mustang 16 11-29-2014 06:21 AM
I have an erratic idle going on 94gtconvert 1979-1995 Mustang GT 24 04-22-2014 09:17 PM
erratic steering Mikeyt03 2011-2014 Mustang GT 8 09-05-2013 01:46 PM
Erratic Idle problem solved-Intake manifold vacuum leak Mercedez L. 1979-1995 Mustang GT 7 07-30-2010 09:08 AM
03:39 PM
