Fuse for brake lights keeps blowing. - Mustang Evolution
Old 08-21-2016, 09:02 PM   #1
99GT4.6's Avatar
The 15A fuse 33 under my dash keeps blowing resulting in my car having no brake lights (or cruise control). If I put a new fuse in and hold down the brake pedal the lights come on for about 15 seconds then the fuse blows again. I tried unplugging the switch on the brake pedal and jumping the terminals with pliers and the fuse blew again so I'm assuming my problem is not with the switch grounding out or failing. I'm planning on getting a multimeter and testing the wiring next. Has anyone else had this problem?
99GT4.6 is offline   Reply With Quote
Old 08-21-2016, 09:58 PM   #2
parkerbickel's Avatar
Check to make sure you don't have a short anywhere.
Sent from my SM-G935V using Mustang Evolution mobile app
2011 V6 Race Red - Roush Axle Back Exhaust, GT500 Steering Wheel, GROM Audio Bluetooth Module, Raxiom Aero Smoked Tail lights, Raxiom GPS
parkerbickel is offline   Reply With Quote
Old 08-22-2016, 07:09 AM   #3
bucko's Avatar
A fuse blows because it's circuit is drawing more then the wiring/fuse can handle. Never install a larger fuse, as the wiring will get hot, and lead to a fire.
Did you recently replace the taillight housings, or the third brake light housing? Did you do any work on the car in or around the brake light housings?
Old 08-22-2016, 07:23 AM   #4
Strange Mud's Avatar
I would start by unplugging the connector to both rear lights and see if it blows...if not one at a time re-connect them this will isolate it to one light. if it still blows remember the 3rd brake light and disconnect that. If it continiues to pop then you have a wiring issue.
Old 08-22-2016, 11:14 AM   #5
twk
twk's Avatar
That is excellent advice right there.
twk is offline   Reply With Quote
Old 08-22-2016, 01:07 PM   #6
99GT4.6's Avatar
Haven't touched the brake light housings or the third brake light this year at all.
Old 08-22-2016, 01:34 PM   #7
Gravydog316's Avatar
Maybe the wiring got wet & damaged (?)
RIP Dick Assman•1934~2016
Old 08-23-2016, 12:01 AM   #8
KATO's Avatar
Fuse Blowing.
The Hardest part is going to be finding the exposed wire that's Grounding out. Could be anywhere, could even be in the Rear near the lights. Good luck finding it.
07 GT. SCT: CUSTOM TUNE by "MUSTANG SPECIALTIES". LMR: GEN2 2010 STYLE HEADLIGHTS, RAXIOM: 2010 SMOKED COYOTE TAIL LIGHTS, WHEELS: STAGGERED WHL 22X8.5F-22X10R.
Old 08-24-2016, 12:23 PM   #9
99GT4.6's Avatar
So I went outside to try to fix this problem and now it is working properly. All lights come on and the fuse isn't blowing. I think this car is possessed. Thanks for the advice everyone!
Old 08-24-2016, 03:29 PM   #10
KATO's Avatar
That's good, but there still maybe a wire that's occasionally touching Metal and Grounding.
Old 08-24-2016, 03:31 PM   #11
99GT4.6's Avatar
I'm sure there probably is. The part that confuses me is it would always take about 15 seconds of pushing the pedal to blow the fuse. It never would blow instantly which I would expect if it had a dead short to ground.
Old 12-23-2016, 11:50 PM   #12
KATO's Avatar
Hey, did you ever find out what that Grounding problem was? Was it a wire or did it completely stop blowing after you tinkered with it?
Old 12-24-2016, 12:42 AM   #13
99GT4.6's Avatar
Completely stopped blowing after I messed with it. The car is in storage for winter now so I'll have to see if it is still good in spring.
FML. Number 18 fuse for ccrm and ignition system keeps blowing 95gtnewb 1979-1995 Mustang GT 0 03-17-2015 05:16 AM
#18 fuse keeps blowing NFLjunkeez 1979-1995 Mustang GT 5 02-22-2013 11:08 PM
Same fuse keeps blowing. Help! blue-saleen Mustang Audio & Video 0 05-11-2011 06:47 PM
#8 Fuse keeps blowing in Ford Mustang... Possible cause? gilmar General Mustang Discussion 2 03-18-2010 11:41 PM
This stupid car again! 1997 mustang fuel pump fuse keeps blowing? camden Pre-2005 V6 Mustang 5 08-23-2009 03:47 AM
07:30 PM
