Clunk and shutter when accelerating - Mustang Evolution
Old 09-10-2016, 08:19 AM   #1
escottcarp's Avatar
My '02 GT has a clunk coming from the rear. It usually happens when accelerating from a stop or from a slow speed. It will happen occasionally when driving slowly, under 20 mph. It happens when coasting over bumps also.
The only rear changes I've made are replacing the LCAs and axle bearings/fluid. I believe the u-joints are good. I suspect the shocks, but when I press down on the trunk, I can't replicate the clunk and the car returns to 'still' immediately. The shocks are not leaking or damaged, either.
Any ideas? Thanks.
escottcarp is offline   Reply With Quote
Old 09-10-2016, 09:07 AM   #2
Revvv's Avatar
Check the torque on the LCAs.
Old 09-10-2016, 09:24 AM   #3
escottcarp's Avatar
The LCAs have poly bushings. If that helps.
Old 09-10-2016, 10:19 AM   #4
escottcarp's Avatar
Old 09-10-2016, 12:58 PM   #5
My car makes some clunking noises as well. I have determined that it is likely caused by the slop in the 100k+ miles drivetrain.
I'm not going to worry about it unless it gets worse, or something breaks.
Old 09-10-2016, 01:14 PM   #6
GaryR's Avatar
Have you actually confirmed the u-joints are ok? The symptoms you describe are classic for that. You can check by forcefully rotating it by hand with the trans in gear (if a manual) or park if an auto and the e-brake on. Try up and down movement on the shaft especially on the pinion end. Easy enough to take the joints apart and confirm and probably one of the least expensive parts to replace if you are able to do it yourself. If you can get it on a lift you can also get a hoist jack under the engine and lift a bit to see if you have a broken motor mount.
GaryR is offline   Reply With Quote
Old 09-10-2016, 01:32 PM   #7
escottcarp's Avatar
I'd say I can confirm the u-joints are good. However, that was not with a tough 'test.' The car (M5) has 131k and it's time to change those anyway. However, the clunks seam to be coming from the sides (I should have said that in the first comment). The car makes the clunk even when coasting. So, I would think this is not a u-joint issue.
Old 09-10-2016, 03:14 PM   #8
GaryR's Avatar
That is indeed a mystery and does not sound like a u-joint if it is apparent at coast. I would be curious to know what you figure out.
Old 09-11-2016, 06:37 PM   #9
fenixignition's Avatar
the little brackets for the e brake cables. did you secure them to the sway bar bolt? or leave them loosey goosey with a couple zip ties like i did?
2002 GT 5sp. 16x,xxx miles
Old 09-11-2016, 11:37 PM   #10
32VALVR's Avatar
^^^^ This...
03 Mach 1
Kenne Bell 2.1 Stock block, built 4r70w w/ Fairbanks, Accufab, SLP, Moser, 3.73, welded tubes, Trick Flow, Magnapack, Megabite Jrs, AFS
1/4 11.57@119.6, 1/8 7.4@95 on NTO5r dr's.
32VALVR is offline   Reply With Quote
Old 09-12-2016, 11:21 AM   #11
Originally Posted by samroush View Post
yea
Let me guess... You are trying to get enough posts to either post in the classifieds, or get the forum AM discount.
Yea?
Old 09-12-2016, 11:24 AM   #12
Revvv's Avatar
Yea?
I'm thinking troll or bot. Regardless, it's irritating. I want to block him, but I'm not a mod. Hmmm
Yea
Old 09-12-2016, 11:35 AM   #13
wmschoonover's Avatar
Yea
Yeah. Know the feeling.
Hope he's not trying to hit his 50 posts lol
wmschoonover is offline   Reply With Quote
Old 09-14-2016, 07:47 PM   #14
Steve96's Avatar
Yea
1996 GT
Old 09-26-2016, 12:02 PM   #15
escottcarp's Avatar
Felix, yes, I can verify that the e-brake cables are attached correctly. I've ordered a pair of shocks. Since, I can't determine the cause, I'm left with replacing parts until I solve the problem. I'll let you know what happens.
Old 10-04-2016, 12:02 PM   #16
escottcarp's Avatar
Just changed the shocks. Same clunk and shutter still happening. Argh!
Old 10-06-2016, 07:16 PM   #17
escottcarp's Avatar
So, I removed the quad shocks. No more clunk or shutter! Yippee!
Old 10-06-2016, 11:29 PM   #18
Interesting. We're they the old factory ones?
Sent from my SM-G920V using Mustang Evolution mobile app
Old 10-06-2016, 11:48 PM   #19
32VALVR's Avatar
Ditto^^^. How does the the car feel/launch without them?
03 Mach 1
Old 10-07-2016, 12:05 AM   #20
With his replaced lower arms, it should launch just fine without them. Sometimes they recommend removing them just because they become pointless. Didn't think they would cause an issue like this.
Old 10-07-2016, 08:02 AM   #21
escottcarp's Avatar
These were the old factory quads. One had dried grease all over it. The other did not extend fully when I pulled on it.
The car is very smooth, now, without the quads, when launching. Big surprise what an affect the old quads had. I'm thinking that it might be good to put new ones on now that I know the poor effect the old ones did. I'll drive it a few days, then, decide.
After changing the 'regular' shocks a few days ago, I've been surprised at how quiet the car has been, too.
I've had trouble since I bought the car 3 1/2 years ago with wearing out rear tires. I've been getting around 8,000 miles out of each set. I wonder how much of that excessive wear has been, simply, from these four bad shocks. I drive the car easy, too. No burn outs, spins, hard cornering or launches.
Old 10-07-2016, 08:06 AM   #22
PARTSFROMERIK's Avatar
I don't think the shocks had anything to do with wear... Maybe that heavy foot on launches did ;D lol... Does the car get wobbly without the quads???
PARTSFROMERIK is offline   Reply With Quote
Old 10-07-2016, 08:09 AM   #23
escottcarp's Avatar
It hasn't felt wobbly or maybe, I just haven't recognized a wobble. I have wondered if I would feel a wobble since some people have commented that they did.
I'll drive a few days and give a better 'wobble' report.
Old 10-07-2016, 08:12 AM   #24
Thanks lol, I know my car is probably a lot lower than you (barely any travel haha) I might take mine off this weekend..
Old 10-07-2016, 08:15 AM   #25
escottcarp's Avatar
Mine is mostly stock. I do have tubular LCAs, but the car is not lowered.
Old 10-07-2016, 08:19 AM   #26
Oh ok, no I have KW coil overs. with front tubular control arms.. I'm no longer into speeding around after a blown engine lol.. low and slow makes my day go by
Old 10-07-2016, 08:25 AM   #27
escottcarp's Avatar
Ha! 'Low and slow' very funny.
I've tracked fuel mileage since I bought it... 22.8 mpg combined city/hwy..... Yes, it is a GT.
Old 10-07-2016, 08:30 AM   #28
On prem? I avg about 19mpg or so. CAI, 75mm throttle body, 60lb injectors, x pipe, and some other crap
Old 10-07-2016, 08:38 AM   #29
escottcarp's Avatar
I'm stock... No CAI, either. Regular gas.
Old 10-07-2016, 08:42 AM   #30
Hmm, I can't run regular gas for some reason car runs crappy lol. very boggy
Old 10-07-2016, 08:47 AM   #31
escottcarp's Avatar
I do have Flowmaster 40's. Forgot that one. Love the sound, too.
I have some of the typical replacements such as COPs, brake calipers, bullet wheels (staggered), etc.
Old 10-07-2016, 08:50 AM   #32
Same here, Hmm I gotta get to work on my car this weekend lol.. brake lights stop working intermittently when pressing brakes.. The smell of gas smell also intermittent D:
Old 10-07-2016, 02:31 PM   #33
escottcarp's Avatar
Good luck with both projects! Both of those problems can have dangerous outcomes.
Old 10-07-2016, 02:37 PM   #34
Brake lights i'm just assuming its a loose connection lol.. and the fuel smell I believe its the breather valve under the passenger wheel well
Old 10-08-2016, 07:53 AM   #35
Project Pony's Avatar
I've seen as low as 12, heavy foot. Also seen as high as 29, coming back from Mustang Week. Cruise set at 70. Mostly stock. Tune, and catless exhaust. 93
non-ethanol. Automatic.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
2013 v6 automatic mustang clunk when re-accelerating jerrysun 2011-2014 V6 Mustang 16 12-09-2014 12:58 PM
Shutter... acwatson03 Pre-2005 V6 Mustang 1 05-05-2014 04:44 AM
Clutch Shutter Delta vt 2011-2014 Mustang GT 1 05-24-2012 08:57 AM
Shutter 96CobraConv SVT Mustang 1 12-07-2011 04:56 PM
02 shutter felt in rear axel fpierce General Mustang Discussion 12 08-14-2011 10:28 AM
10:13 PM
