Need to build my tr3650 for 500rwhp and possibly 700rwtq - Mustang Evolution
Old 09-12-2016, 08:15 AM   #1
Speed_Mister's Avatar
Region: Arkansas
I need to build my tr3650. Planning to run a 250 shot thru it. Possibly 700rwtq and plan to make 500rwhp. What all do I need to make it work to withstand hard launching on radials. Any info helps. Already have 26 spline input shaft.
2004 Mustang Gt
5 speed manual
Full bolt ons
Built moser rearend
395rwhp 500rwtq
11.8 @ 115
7.5 @ 92
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 09-12-2016, 10:05 AM   #2
Send it to the 3650 source and tell them you want it to hold that much. They do amazing trans builds.
Old 09-12-2016, 10:31 AM   #3
Revvv's Avatar
I wish I knew more about rebuilding transmissions. They are a simple mechanical assembly, but one small miscalculation screws everything up.
Revvv is online now   Reply With Quote
Old 09-12-2016, 09:02 PM   #4
32VALVR's Avatar
I had my 3650 rebuilt twice under ESP. I then had it fail again, (always 2nd or more often 3rd) and had it rebuilt out of my pocket even though I told this local tranny pro that we should prolly go T56. He said "no will build it tough enough". After having it fail two more times, I finally twisted the input shaft on the fifth fail to when he said, (you can't keep this up, and suggested a T56 swap)... I purchased a complete 03/04 Cobra swap with a 26 spline input conversion and had them install the whole kit and combudle. While it was great on the street, the gearing sucked at the track.
I am now built 4R70W and love it! Except coming down a canyon.
In all respect, I don't think anyone can make a crappy 3650 handle the power your talking about. If you really want to stay manual, I would go withe a TKO 600, which can handle the power, but are sloppy shifters. You could also get a 295 first gear Magnum XL, but they are pricey and heavy.
I wouldn't waste my time on a 3650!
03 Mach 1
Kenne Bell 2.1 Stock block, built 4r70w w/ Fairbanks, Accufab, SLP, Moser, 3.73, welded tubes, Trick Flow, Magnapack, Megabite Jrs, AFS
1/4 11.57@119.6, 1/8 7.4@95 on NTO5r dr's.
32VALVR is offline   Reply With Quote
Old 09-12-2016, 10:34 PM   #5
Region: Arkansas
What all did you not like about t56 on track?
2004 Mustang Gt
5 speed manual
Full bolt ons
Built moser rearend
395rwhp 500rwtq
11.8 @ 115
7.5 @ 92
Full Bolt Ons
370rwhp 470rwtq
Old 09-13-2016, 03:06 PM   #6
32VALVR's Avatar
[QUOTE=Speed_Mister;2393361]What all did you not like about t56 on tr/QUOTE]
2.66 1st gear.
Old 09-13-2016, 04:54 PM   #7
Region: Arkansas
[QUOTE=32VALVR;2393462]
2.66 1st gear.
Hmm I have 2.90 gears in 1st with 4.10 gears and a 28" tire and mines pretty short gear. Is that 2.66 to long?
2004 Mustang Gt
5 speed manual
Full bolt ons
Built moser rearend
395rwhp 500rwtq
11.8 @ 115
7.5 @ 92
Full Bolt Ons
370rwhp 470rwtq
Old 09-13-2016, 06:01 PM   #8
32VALVR's Avatar
[QUOTE=Speed_Mister;2393476]
2004 Mustang Gt
5 speed manual
Full bolt ons
Built moser rearend
395rwhp 500rwtq
11.8 @ 115
7.5 @ 92
It was for me. How are you making 500rwtq, are you spraying?
03 Mach 1
Old 09-14-2016, 05:42 AM   #9
Region: Arkansas
Yes
2004 Mustang Gt
5 speed manual
Full bolt ons
Built moser rearend
395rwhp 500rwtq
11.8 @ 115
7.5 @ 92
Full Bolt Ons
370rwhp 470rwtq
Old 09-14-2016, 10:31 PM   #10
32VALVR's Avatar
Well that certainly explains your killer tourqe numbers. If your rolling through a stock 3650, your 1st gear is 3.28 or 3.27.
I forget, but its definitely not 2.90.
Old 09-16-2016, 10:37 AM   #11
Lorraine's driver
ab_mach1's Avatar
2.66 1st gear.
They so have a 2.97 version available.
http://www.ddperformance.com/79-04-ford-t-56-magnum/
Instagram: @ab_mach1
Old 09-16-2016, 10:38 AM   #12
Lorraine's driver
ab_mach1's Avatar
is site appears to offer built 3650's.
Rebuilt TR3650 Transmissions in Atlanta Georgia
There doesn't appear to be that many out there that mess with the 3650.
Old 09-16-2016, 03:24 PM   #13
Ish416's Avatar
I agree with most of what 32VALVR wrote.
Where I disagree is that the 2.66 1st gear is not good for the track. A taller first gear is a good thing in a car that makes good power. My Z28 makes 430 whp and 400 wtq on motor and 588 whp and close to 700 wtq (not including the 750+ wtq spike on the initial hit) on a 150 shot.
In day to day driving, my car gets 26+ MPG on the highway with 3.42's and can run up to 62 MPH in 1st gear (7200 RPM, 285/40/17 and 3.42 gear) and it never feels like its to tall of a gear.
On the track, that tall 1st gear helps minimize wheel spin when properly driven. Attached is a time slip showing that the car moves off the line pretty well with that tall 1st gear.
Also, the T56 is a tough as hell transmission and will take SERIOUS abuse before it will break.
As the former owner of a car with a TKO 600, it can hold power but it's a horrible shifting transmission.
Old 09-22-2016, 08:29 PM   #14
Region: Arkansas
Well looks like I'm just rebuilding my tranny.. I guess I'm getting a deluxe synchro ring kit with all rings for all gears, bronze shift fork pads.. idk what else to maybe upgrade in this tranny while I'm in there.
2004 Mustang Gt
5 speed manual
Full bolt ons
Built moser rearend
395rwhp 500rwtq
11.8 @ 115
7.5 @ 92
Full Bolt Ons
370rwhp 470rwtq
500rwhp 3V bismofunyuns 2005-2010 Mustang GT 8 04-29-2015 08:38 PM
For Sale: TR3650 5 Speed and Ram Dual Disk Clutch ColeJohnson Mustang Parts for Sale and Wanted 4 02-17-2014 04:20 PM
Tr3650 to t45 Jose08 1996-2004 Mustang GT 0 04-19-2012 05:02 PM
Steeda tri-ax tr3650 spooky Mustang Parts for Sale and Wanted 3 01-12-2007 08:00 AM
500RWHP Broken GT-Eater Pre-2005 V6 Mustang 47 03-25-2005 09:43 AM
10:07 PM
