V6 to v8 swap - Mustang Evolution
Old 09-15-2016, 09:30 PM   #1
Blue Angel's Avatar
V6 to v8 swap
I swaped out my old v6 n put a v8. I changed everything over from a donor car being instrument panel ignition cylinder computer and the key from the door in car everything is hooked up properly but the car will not start it just cranks but no fire the fuel is all hooked up properly but there is still no fire anybody know what it could be?
Sent from my SM-N910P using Mustang Evolution mobile app
Blue Angel is offline   Reply With Quote
Old 09-15-2016, 11:00 PM   #2
When you turn the key to the on position do all of the warning lights in the instrument cluster light up as normal?
Is the theft light flashing when the ignition is in the on position?
Old 09-16-2016, 04:04 AM   #3
Blue Angel's Avatar
Yes all the lights come on and it clicks when itry n start it but no crank, no the theft light is not flashing
Old 09-16-2016, 05:44 AM   #4
If it clicks, Check out the battery. It may not have enough juice to crank it over.
Old 09-16-2016, 06:03 AM   #5
jkeaton's Avatar
Click but not turning over is indicative of a weak battery or bad connections. There is a difference between not turning over and not starting.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 09-16-2016, 06:03 AM   #6
wmschoonover's Avatar
I'd also check all the connections at the frame, both battery posts and the starter. Check for corrosion and or loose connections.
wmschoonover is offline   Reply With Quote
Old 09-16-2016, 09:38 AM   #7
Blue Angel's Avatar
We had it hooked up to a jump starter n still nothing even tryed with a brand new battery
Old 09-16-2016, 09:40 AM   #8
Blue Angel's Avatar
This is the only thing that dosent match up with the body harness on my car (the v6) the engine harness is the v8 ofcourse. Do i need to switch it out?
Old 09-16-2016, 10:26 AM   #9
Lorraine's driver
ab_mach1's Avatar
Yup!
Instagram: @ab_mach1
To Swap, or not to swap...... Strongarm 1979-1995 Mustang GT 5 02-05-2008 01:39 PM
07:43 PM
