17 to 18 inch wheels - Mustang Evolution
Old 09-18-2016, 08:17 PM   #1
rdwelch's Avatar
Ok, to those that have gone to a 18 inch set of wheels, what are the downsides? I assume a flash is required to get the speedo to read correctly. I have an 03 GT and want 10.5 wide wheels in back.
rdwelch is offline   Reply With Quote
Old 09-18-2016, 08:58 PM   #2
Mile high JDF's Avatar
Most 18s only go up to 10" wide. Weight is one difference, 18s will be slightly heavier depending on the wheel and tire you pick. You won't need to flash the speedometer/change the tune unless you go with a tire with a larger diameter in the rear. What size tires were you thinking?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-19-2016, 06:01 AM   #3
rdwelch's Avatar
Was thinking of installing 17s all around at first, with 17x10.5 on rear with tire size 315/35/17. I do not know what tire size would be best with 18 inch.
Old 09-19-2016, 06:29 AM   #4
I've got 285s on mine right now, generally the largest people will go with an 18 is a 305/35 in the rear.
Old 09-19-2016, 09:25 AM   #5
jande063's Avatar
One advantage to an 18 is that there is a better selection of high end tires in wide sizes. That said, tires do cost more on an 18 than on a 17.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 09-19-2016, 11:19 AM   #6
rdwelch's Avatar
Anyone regret going to an 18 size wheel?
Old 09-19-2016, 12:56 PM   #7
Other than tire price, nope. 295/35 on wife's car.
Old 09-19-2016, 01:39 PM   #8
PARTSFROMERIK's Avatar
That is what I am running
PARTSFROMERIK is offline   Reply With Quote
Old 09-19-2016, 01:55 PM   #9
rdwelch's Avatar
You like the size/setup?
Old 09-19-2016, 03:36 PM   #10
SolarFlarin's Avatar
Region: Rhode Island
You can get 10.5 in the rear with 17 inch ..
SolarFlarin is offline   Reply With Quote
Old 09-19-2016, 05:56 PM   #11
Literally just installed them and forgot about them. Not even a flash
wawanesa5speed is offline   Reply With Quote
Old 09-19-2016, 06:57 PM   #12
Project Pony's Avatar
18s would be a 10" wheel with between a 285 and 305 depending on what rubber you go with. I got a buddy with 18x10 wrapped in 305s. Lowered about 2". He runs into rubbing issues now and then, but it does look good.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 09-19-2016, 09:23 PM   #13
Region: New Mexico
18s on my 2007, 255 front, 285 rear. Fills the fender cavity and no rubbing. Didn't flash, not enough difference to worry about.
rogcat1 is offline   Reply With Quote
Old 09-20-2016, 04:38 AM   #14
Yours is a s197, we are talking about new edges.
[SIGPIC][/SIGPIC]
Old 09-20-2016, 09:53 AM   #15
XSlashDashX's Avatar
I'd go with 18s. Looks the best when lowered.
Old 09-20-2016, 07:40 PM   #16
Westcoast408's Avatar
If you get the rovo durbans. They are 18x9 and 18x10.5 for the rear
Sent from my SM-G920T using Mustang Evolution mobile app
99 Mustang GT F.R 3.73s, MGW Short Shifter, BBK Cai, BBK 70mm Throttle Body, Mach 1 Chin Spoiler, SR Lowering Springs, Koni shocks and struts, Mach 1 Grill Delete, Black Billet Fuel Cap, Trick Flow 75mm Plenum, Raxiom Smoked Tail lights, Magnapack Mufflers
Westcoast408 is offline   Reply With Quote
Old 09-22-2016, 07:22 PM   #17
Steve96's Avatar
Exactly. They are some nice wheels. 10.5 looks good in the 18 in the rear. They are light too. They were lighter than my 17" bullits. I never bothered to look at the weight of them exactly because it doesnt really matter much to me anyway. But I can tell they are lighter than some 17s Ive had.
1996 GT
Old 10-29-2016, 05:00 PM   #18
RealRedRaider's Avatar
On my son's 2004 RedFire Convertible, we went with:
Front - 18" x 9" - 265/35ZR18
Rear - 18" x 10" - 295/35ZR18
Fit is perfect!
Next up is to lower both front/rear utilizing Maximum Motorsports front coil-over conversion, front lower control arms, caster/camber plates, rear HD adjustable height control arms, rear MM springs along with Bilstein struts and shocks.
"You can all go to hell and I will go to Texas!" ~Davey Crockett
RealRedRaider is offline   Reply With Quote
Old 10-29-2016, 06:54 PM   #19
jeno's Avatar
Fit is perfect!
Very nice
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 10-29-2016, 09:27 PM   #20
Thanks everyone, that maroon anniversary edition is saaaa weeeeeet. Appreciate the help. I'm gonna go with the 18's staggered.
Old 10-30-2016, 09:09 AM   #21
Steve96's Avatar
Looks great! It will look so awesome once lowered!
1996 GT
Old 12-03-2016, 06:51 AM   #22
edross's Avatar
These are 18 inch staggered, 275 in the front, 295 in the rear
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 12-03-2016, 08:26 AM   #23
wmschoonover's Avatar
Looks great!
wmschoonover is offline   Reply With Quote
Old 12-03-2016, 05:10 PM   #24
Looks good
[SIGPIC][/SIGPIC]
Old 12-03-2016, 05:30 PM   #25
Joshy's Avatar
I love the 18's on mine. They look pretty good. I need a little drop on mine still.
Sent from my SM-G930V using Mustang Evolution mobile app
www.petom.biz
Joshy is offline   Reply With Quote
Old 12-04-2016, 03:19 PM   #26
Do you get any rubbing in the rear with the 295?
Old 12-05-2016, 03:29 AM   #27
edross's Avatar
Not at all
15 inch or 17 inch rims Vistablue Mustang Wheels & Tires 21 01-11-2013 05:15 AM
15 inch wheels 559Danny 1996-2004 Mustang GT 0 10-07-2011 12:52 PM
3.5 inch or 4 inch tips? 2002Gt 1996-2004 Mustang GT 73 06-19-2011 09:29 PM
Would I be able to fit 16 or 17 in wheels on a 15 inch tire? sk8brdkd Mustang Wheels & Tires 27 05-20-2010 01:33 AM
where can i get some damn 13x5 inch wheels??!?! fast64 The Bar 17 09-25-2005 05:12 PM
03:02 AM
