Break booster or master cylinder 01 bullitt - Mustang Evolution
Old 09-19-2016, 11:58 AM   #1
I was on the way to work Friday morning when I bumped into a car in front of me after my breaks failed and the pedal went to the floor with not much compression at all, thank goodness I was using the gears to slow me down to begin with which ultimately made it to where there were no damage on either vehicle.
Now I have tried to bleed the breaks first, and barley any fluid comes out of the bleeder valve when the pedal is engaged. so I continued to see if it was like that all the way around which it was, but then I found where the metal break line meets with the break hose to go in to the caliper is leaky a little bit on the metal break line portion of the connection (on drivers front side)
I have gotten a new metal break line and going to replace it this week but also I need to find out weather this problem screams master cylinder or break booster because they are significantly different in prices and im not sure which is the problem if anyone could help me figure this out I would greatly appreciate it!
shermanator11 is offline   Reply With Quote
Old 09-20-2016, 06:41 PM   #2
The symptoms point towards the master cylinder. Once you have the brake line replaced, try bleeding the master before bleeding the brakes. Possibly, it became low on fluid and now there is air trapped inside.
And when you are bleeding the brakes, keep a close eye on the fluid level of the master cylinder. Do not let the fluid level become too low.
Old 09-21-2016, 08:25 AM   #3
thank you for that I didn't even think of air getting trapped in the master cylinder itself, ill try that tomorrow morning, and get back to you!
Master cylinder mistake duals 1996-2004 Mustang GT 5 04-15-2009 09:11 PM
master cylinder to brake boster STEVE 1979-1995 Mustang GT 11 02-04-2006 11:46 PM
10:06 PM
