Won't start - Mustang Evolution
Old 09-26-2016, 03:12 PM   #1
Region: Oregon
Won't start
Here we Go. 96 gt. It won't start. When I put starter fluid on it, it will fire up and run great. I decided to change the regulator. No change. Even though I can hear the fuel pump I went ahead and changed rthat too. It fired right up. Then when I went to start it again it just cranked. This time I can't here the fuel pump. Now what?
Bloodlan is offline   Reply With Quote
Old 09-26-2016, 03:43 PM   #2
wmschoonover's Avatar
Did you check the fuel filter?
Name:	ImageUploadedByMustang Evolution1474926186.013899.jpg
wmschoonover is offline   Reply With Quote
Old 09-26-2016, 05:51 PM   #3
Region: Oregon
Yes. Put in new fuel filter.
Old 09-26-2016, 07:16 PM   #4
First, you should check the fuel pump inertia safety switch, and make sure that there isn't a problem with it, and voltage is entering and leaving the switch.
Second, there could be a problem with the Constant Control Relay Module, which is the relay for the fuel pump, amongst other components on the vehicle. It is located in the passenger side fender, and is accessed by removing the inner fender. If it is found that the CCRM is at fault, the entire component must be replaced.
Old 10-02-2016, 06:30 PM   #5
Region: Oregon
Seems it was a bad connection to the pump.
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 07:52 PM
ooooooook, so engine won't start jimmy_beaner Pre-2005 V6 Mustang 24 11-13-2005 05:47 PM
Car won't start V6STANG007 Pre-2005 V6 Mustang 31 12-07-2004 06:07 PM
my 3.8 2001 mustang won't start sahba22 Pre-2005 V6 Mustang 7 01-19-2004 03:21 PM
10:06 PM
