spark plug problem please help - Mustang Evolution
Old 09-30-2016, 12:26 PM   #1
mustang_brody's Avatar
my 04 mustang gt keeps shooting spark plugs out this is the second time this has happened do anybody know why this happens and why does it happen b/c its costing me a lot of money to pay people to re thread them so i can drive it need help asap
mustang_brody is offline   Reply With Quote
Old 09-30-2016, 12:43 PM   #2
Mile high JDF's Avatar
Well the original issue is the spark plugs were over torqued when they were replaced and it stripped the threads out. Is it the same plug that keeps coming out or is it different each time?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 09-30-2016, 01:32 PM   #3
Different each time
Old 09-30-2016, 01:57 PM   #4
Revvv's Avatar
The plugs are being over torqued. You have aluminum heads and steel plugs. Steel is stronger than aluminum. You need to install them with anti seize and torque them down no more than 12 ft lbs (someone else needs to confirm that for me). The biggest problem is due to the small amount of threads that exist. There is not much for the plug to grab, and when you over tighten the spark plug it tears the threads out instead of tightening.
Old 09-30-2016, 02:25 PM   #5
jkeaton's Avatar
Sounds like he is getting them rethreaded and then whoever is installing them is stripping them out again.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is online now   Reply With Quote
Old 10-01-2016, 12:14 AM   #6
no its a different one each time
Old 10-01-2016, 07:40 AM   #7
jkeaton's Avatar
Get them all done at once then. Or the rest of them. As stated, someone overtorqued them.
Old 10-01-2016, 09:47 PM   #8
32VALVR's Avatar
I've seen this problem with early 4V heads. I can only relate what I've read as I've never had this issue, even though I have early 03 heads.
The real problem as stated prior is the lack of threads on these mod motors. I don't think over torquing is your problem, its just inherent. I've always torqued my plugs with anti-seize to what feels like a ring washer sealing. These dudes aren't re- threading your heads but, inserting a helicoil to solve your issue. I would just get some really late, or aftermarket heads wit more threads and be done with it.
03 Mach 1
Kenne Bell 2.1 Stock block, built 4r70w w/ Fairbanks, Accufab, SLP, Moser, 3.73, welded tubes, Trick Flow, Magnapack, Megabite Jrs, AFS
1/4 11.57@119.6, 1/8 7.4@95 on NTO5r dr's.
32VALVR is offline   Reply With Quote
Old 10-04-2016, 04:52 PM   #9
XSlashDashX's Avatar
Torque to 13 using antisieze. Use that on my 04 after blowing a plug and never had a problem afterwords.
Spark plug wire problem Bschmidty 2005-2010 V6 Mustang 9 08-04-2014 10:00 PM
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 09:42 AM
Ford Racing 9mm Spark Plug Wire Problem 95GTease 1979-1995 Mustang GT 3 07-17-2012 04:10 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 10:45 AM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 12:37 PM
06:59 AM
