Steering shaft play - Mustang Evolution
Old 10-07-2016, 08:00 AM   #1
PARTSFROMERIK's Avatar
Steering shaft play
I have about an inch back and forth of steering wheel play. What could be causing this?
PARTSFROMERIK is offline   Reply With Quote
Old 10-07-2016, 09:53 AM   #2
jeno's Avatar
Steering rack
Sent from my SM-N910T using Mustang Evolution mobile app
---------- Post added at 03:53 PM ---------- Previous post was at 03:53 PM ----------
Bad tie rods
jeno is offline   Reply With Quote
Old 10-07-2016, 11:34 AM   #3
Originally Posted by jeno View Post
Steering rack
Bad tie rods
Complete new rack lol hmm idk
Old 10-07-2016, 01:20 PM   #4
So I will assume that new steering rack bushings were installed at that time.
It could be anything from merely being out of alignment, to a worn out front end component. Like Jeno said, check your tie rods, ball joints, A-arm bushings, and the steering shaft, for any play.
These cars are getting to the age where it is a good idea to rebuild the entire front suspension when something wears out, rather than doing it piece by piece over the years. That way the car will at least drive as good as new... While the rest of it falls apart around you!
Old 10-07-2016, 01:28 PM   #5
Lol I have to believe its the steering shaft bushing (sadly you have to buy the entire shaft ) D: I had a collision and I changed the whole front subframe with arms, everything lol except the shaft D:
Old 10-07-2016, 02:20 PM   #6
jeno's Avatar
Since you did that then I would say the steering shaft
Balancing drive shaft or replacing drive shaft Iryan7 Pre-2005 V6 Mustang 6 03-22-2015 11:57 AM
A little "play" in the steering wheel issue Tobyg77 1996-2004 Mustang GT 5 10-27-2014 09:18 AM
Steering wheel has a little play Tobyg77 1996-2004 Mustang GT 6 08-15-2014 07:30 AM
Play in steering Kbasham5 1996-2004 Mustang GT 2 02-25-2014 03:33 PM
steering wheel play greenpony02 1996-2004 Mustang GT 2 01-04-2008 07:02 AM
» Members Mustangs
skully
skully
Ruby
JAC20
Add your Mustang
10:49 PM
