Have found what looks like a great deal on a set of Ready to bolt on DOHC heads with new cams, valve covers and FR500 style aviator intake for $750. Want to know if this set up will work on a 4.6 SOHC block? Because I have also found a 4.6 with an Eagle rotating assembly and probe Pistons (.020 over standard bore). Anyone have any thoughts on this combo?
Cool thanks for the info. Gonna replace my SOHC engine with a used cobra engine or maybe the setup I mentioned above. Just weighing my options and want to get the most bang for my buck. This is a daily driver so I don't want to hot rod the car but I do want more power. I can't leave anything of mine bone stock. Lol
Kinda. Except the heads are tumble port which I'm told are suppose to be the best DOHC heads. The cams are actually like a step up from the 2001 cobra cams. The short block has eagle crank and rods with probe Pistons (.020 over stock bore).
I would make sure there is valve clearance in the pistons for the second set of valves.
Might be a non issue or a catastrophe depending on the pistons used in that particular block.
I know the Pistons in my 3 valve stroker would not allow a second set of valves but that may just be a 3 valve thing. Might not even be an issue, but I'd want to be sure.
Yeah I've thought about that. I have a great machinist who I'll have check that out if I go this route. I think I can make more HP with setup but I'm leaning on just dropping in aloe mileage ready to go cobra motor. For me that will be easier and I thin cheaper in the long run.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
