04 GT hard start - Mustang Evolution
Old 08-10-2008, 08:48 PM   #1
04 GT hard start
Ive got a friends automatic 04 GT Ive been messing with for a long time. It has a hard start problem that happens everytime after filling up and the next few starts after that untill the fuel level is down some. Any thoughts on this? Things like tune up, fuel filter, pump, iac, etc can be rule out as they have been replaced. Ive heard on another board about the "horrible evap problem" but no one went into detail of what that problem is. I made note of what FTP and FTPv is while it was starting ok. I wonder if its a pressure sensor or something else down the line in the evap system, but, I also havent replaced the fuel cap. Thoughts?
4.6fox is offline   Reply With Quote
Old 08-11-2008, 07:11 AM   #2
Re: 04 GT hard start
one test to try would be to fill up and let it sit for a few minutes before cranking to see if it makes a difference. If it does it could be something as simple as trash getting stirred up in the tank and messing with the filter~ but I doubt that one. Is the fuel pressure good?
Old 08-11-2008, 08:01 AM   #3
Ive got like 40-42 pounds at an idle, atleast when its not acting up. There shouldnt be anything in the tank, I steamed it out when I pulled it to put a new pump in, and I also replaced the filter then. Seems like nothing Ive done has even started to touch it.
Old 08-11-2008, 09:06 AM   #4
there is a check valve that keeps pressure up or something in the line for starting~ I know when 03/04 cobra guys turn this off (it causes a hesitation in shifting at high rpms) it makes the car harder to start~ thats about the only other thing I know of that might cause the issue, its a switch or something on the pump that can be turned on/off
Old 08-11-2008, 10:10 AM   #5
1234's Avatar
Where is that located?
How do you shut it off?
Old 08-11-2008, 10:55 AM   #6
it is a check valve in the fuel pump assembly in the tank, you have to remove the intank lines and use a non-deteriorating rubber hose to replace it.
SimplyOrange is offline   Reply With Quote
Old 08-12-2008, 05:06 AM   #7
Well, I really dont think thats what the problem is since this isnt an intermittent problem. It will do it every time after filling and the next couple starts after that. Besides, the cobra fuel pump setups are different than the GTs arent they?
Old 08-12-2008, 11:58 PM   #8
MonteCitan's Avatar
Describe your 'hard start' does it crank a lot? does it crank slow? does it start then hesitate/stumble?
Hard to diagnose this type of problem without seeing how it acts first hand
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-13-2008, 04:53 AM   #9
It cranks fast enough, but its an extended period of time. When it does start, sometimes it will die, but if you hit the key again, it will fire right up and be fine. If it does the extended crank and does start, it stumbles around quite a bit untill it gets itself going.
Old 08-13-2008, 06:34 AM   #10
try cycling the key a few time next time you fill up and start it, if that works fine, you are having a priming issue that can be cause by a failing pump.
Old 08-13-2008, 08:15 AM   #11
I know its not a low fuel pressure problem, we had a gauge on it while it was acting up and didnt see a problem, plus its got a new motorcraft pump in it because the sender went out a while back.
Old 08-13-2008, 08:58 AM   #12
DarkShadows's Avatar
May be gas getting into the canister? when you fill up to you top off?
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 08-13-2008, 09:21 AM   #13
that is possible, has it had ethanol in it by chance?
Old 08-13-2008, 09:32 AM   #14
She always runs 87 octane from Quick Trip which as far as I know is ethenol free, although I think almost every gas company can put up to 10% in without labeling. As far as I know she fills it till it clicks and stops. Far as checking the canister for gas, its up under the right fender isnt it? If thats the case, whats the cause of it happening?
Old 08-13-2008, 10:23 AM   #15
overfilling could put gas in the canister vent tube. may cause hesatation. i know thats the case in Nissans not sure about fords.
would this be hard to do? PenguinFan Pre-2005 V6 Mustang 6 09-08-2009 08:24 AM
Hard Drive IS going out now. Brent ME Site Help & Announcements 13 04-15-2009 09:47 AM
Breaking Up Is Hard to Do! My 5.0 jwyche 1979-1995 Mustang GT 27 02-17-2009 09:35 PM
its hard to get races... Tbird232ci The Bar 10 02-25-2005 01:28 PM
how hard would it be?? fast64 The Bar 21 01-10-2004 03:49 PM
06:14 PM
