clutch cable - Mustang Evolution
Old 03-17-2017, 06:05 AM   #1
Senior Member
clutch cable
hey guys. so ever since I got my 01 gt about 2 months back it's had an extremely hard clutch. the clutch grabs fine but it's just vert hard to push in. I'm thinking it could be the cable? it has a firewall adjuster and aluminum quadrant. I tried adjusting it but it doesn't change the stiffness only the grabbing point. what do you guys think? and what are symptoms of a bad clutch? thanks
arena314 is offline   Reply With Quote
Old 03-17-2017, 07:36 AM   #2
jkeaton's Avatar
Symptom of a bad clutch is it slips.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 03-17-2017, 09:02 AM   #3
Senior Member
well I know that. but someone felt my clutch and asked why it was so hard I said it's just the cable I gotta put a new one in and he kept telling me it was my pressure plate and my clutch is on borrowed time
Old 03-17-2017, 01:46 PM   #4
infamous281's Avatar
Clutch fork / pivot stud
Sent from my SM-G930T using Mustang Evolution mobile app
Old 03-17-2017, 01:51 PM   #5
Senior Member
I'm guessing I should start by replacing the cable?
Old 03-17-2017, 02:48 PM   #6
Lorraine's driver
ab_mach1's Avatar
I'd look at ^this as well as your cable. On the TR3650 (and I'm assuming the T45's too), you can see the clutch fork and make sure it's on the pivot ball and pivots cleanly when someone up top pushes in the clutch pedal. Make sure your cable is not damaged. Some of the aftermarket cables, like you have (because you have a firewall adjuster and alum quadrant) are not near as durable as the OEM cable. Make sure the cable is centered within the quadrant groove. If it at an angle, it can definitely hinder cable movement as you push in the pedal. Make sure the cable isn't binding in the engine compartment area too.
Instagram: @ab_mach1
Old 03-17-2017, 02:55 PM   #7
Senior Member
so i can't put an oem cable on with the firewall adjuster and aluminum quadrant?
Old 03-17-2017, 04:46 PM   #8
Yes you can with some modification, but I'm against adjustable crap on the clutch cable.
I've experienced so many negative things with adjustable cable components.
Old 03-17-2017, 04:57 PM   #9
Senior Member
what modifications? I was about to but a maximum motorsports cable but maybe I shouldn't now
Old 03-17-2017, 09:40 PM   #10
Lorraine's driver
ab_mach1's Avatar
If you buy the one from MM, it is OEM quality and you shouldn't need to modify it. I didn't have to modify mine anyway. I bought their kit. It also comes with some washers/spacers so you can get your cable lined up for the best motion of the quadrant.
http://www.maximummotorsports.com/Cl...kage-P385.aspx
This kit is totally worth the extra $$ compared to other kits for sale.
Old 03-17-2017, 09:57 PM   #11
Senior Member
would I be able to just buy a cable and make it work since I already have the aluminum quadrant and firewall adjuster?
Old 03-18-2017, 01:32 AM   #12
Lorraine's driver
ab_mach1's Avatar
Yup, check out MM's website. They sell the cable in that kit separately as well. If there is some modification to be done on the cable itself, MM will have instructions on what you need to do. They have their instructions for about everything they sell on their website, so you can look at them anytime. You can also call them if you need info or help.
Old 03-18-2017, 02:21 AM   #13
Senior Member
okay awesome. thank you. so im guessing j should start there since it's the cheapest and easiest to do
Old 03-20-2017, 12:12 AM   #14
If its an aftermarket cable that is 90% going to be your problem. They suck ***. All of them. Anyone who buys the aftermarket cables WILL have problems. And some quadrants too... they aren't all created equal and some of them have a wonky pedal release. My best combo is a stock/MM cable, the MM quadrant and a Fiore (or another microclick) firewall. Feels identical to stock, no issues with adjusting and the cable action is very smooth.
You can get an OEM cable from a dealer or just order the MM one. MM sources their cables from the OEM manufacturer so they are the same.
Old 03-20-2017, 06:24 AM   #15
Senior Member
okay great thanks. I'll order a cable off mm and go from there
Old 03-20-2017, 09:38 PM   #16
dansg's Avatar
Send a message via Yahoo to dansg
clutch cable.
I found you have to take out the bolt from the fender. it causes binding. it messed 2 of my cables up. just take the bolt out and it will be like a new clutch. I took the bolt out and never had a problem again.
dansg is offline   Reply With Quote
Old 03-21-2017, 05:18 AM   #17
Senior Member
really?
Old 03-22-2017, 01:13 PM   #18
I have no idea what he is talking about honestly.
Old 03-22-2017, 01:14 PM   #19
Senior Member
I never heard tat before
Clutch cable? cstyle408 1996-2004 Mustang GT 6 10-03-2014 11:13 PM
Clutch cable Scottnos1 1979-1995 Mustang GT 23 06-25-2014 12:18 PM
clutch cable ricky1379 1979-1995 Mustang GT 11 04-30-2014 07:09 PM
Clutch cable Cstyle1 1996-2004 Mustang GT 2 01-27-2014 06:05 PM
Clutch or clutch cable acting up 99mustang99 1996-2004 Mustang GT 4 07-13-2013 01:38 PM
12:03 AM
