Clutch assembly set up question - Mustang Evolution
Old 08-05-2017, 02:13 AM   #1
69ponyxprs's Avatar
Morning guys and gals. I have a question. Someone once posted the part number for a clutch / pressure plate setup that's offered at NAPA. Can't remember the brand type, but suppose to be one of the better brands and this company makes the NAPA brand. Only difference is the packaging. If someone could help me out I'd appreciate it. Thanks.
69ponyxprs is offline   Reply With Quote
Old 08-08-2017, 12:40 PM   #2
jkeaton's Avatar
Probably someone at NAPA can.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 08-08-2017, 01:59 PM   #3
Revvv's Avatar
I say go with an Exedy Mach 1 and call it a day.
I am curious about Centerforce in these cars.
---------- Post added at 02:59 PM ---------- Previous post was at 02:59 PM ----------
Google it for the OP
Old 08-09-2017, 12:17 PM   #4
Just get a whole new clutch assembly if yours is bad.
Exedy Mach 400 and call it good. Nice light pedal feel and will hold as much torque as the stock input shaft can take.
Old 08-10-2017, 05:15 AM   #5
69ponyxprs's Avatar
So that would be good to use with the stock cobra engine as well? This is for the engine swap I'm doing. The original clutch definitely needs replacing. I don't really know the condition of the cobra clutch seems ok in the car but can't really drive it as is. I figured since I was going to have it out, I'd have the flywheel checked and install a new clutch assembly. Btw, my son and I started the swap yesterday evening. Really exited to be back in the shop again even if it's only to direct him. Still under doctor's restrictions.
Old 08-10-2017, 05:29 AM   #6
They use the exact same flywheel and clutch. Well, whatever the crank bolt count is anyway. 8 or 6 bolt, whatever yours is get a new 11" flywheel assembly and an 11" (01-04GT style) clutch.
Old 08-10-2017, 05:43 AM   #7
69ponyxprs's Avatar
Will I need to replace the cable? Should I?
Old 08-10-2017, 06:05 AM   #8
jkeaton's Avatar
Might as well and the quadrant too.
07 V6 Coupe
Old 08-10-2017, 01:40 PM   #9
I like the aluminum quadrant and fire wall adjuster, only use a stock Ford Cable. Have used a few Centerforces and really liked the easy pushing the clutch pedal in in traffic with not so good knees. No slippage or chatter and good longevity.
Neuron is offline   Reply With Quote
Old 08-10-2017, 01:44 PM   #10
Revvv's Avatar
An easier clutch that grabs would be nice. My Exedy is heavy.
Old 08-10-2017, 02:13 PM   #11
Mine wasn't. The Mach 400 was super light.
As for the cable and quadrant... ONLY Max Motorsports/OEM (same) cable or you will have binding. No adjustable cables, no aftermarket, don't do it. You have been warned lol.
Quadrant... Max Motorsports again. For the firewall adjuster if you can find a Fiore microclick secondhand do it, they are far and away the best. If not... the UPR microclick knock off is ok. I do not like the allen set screw ones, they are a pain in the *** vs the microclick.
Remember when you set your cable tension the throwout bearing is REQUIRED to be spinning at all times. What I do is get the car on ramps, start it with the wheels chocked and someone in the car with their foot on the brake/e brake set and then shine a flashlight into the bellhousing by the clutch fork and tighten the adjuster up until the TOB just starts to spin. Then go 1/4-1/2 turn tighter and you are good, that is your good preload.
Oh, also a new fork, throwout bearing and pilot are a good idea, again, OEM Ford. Just get them from a dealership. Just FYI, OEM Ford and Ford Racing are not the same. OEM is always best for these.
Old 08-10-2017, 02:15 PM   #12
Revvv's Avatar
Good advice Scotty.
Old 08-14-2017, 07:33 PM   #13
69ponyxprs's Avatar
Cool thanks! I'll get those items ordered. Will be pulling the engine this week from both cars and installing the dohc hopefully this weekend. Appreciate everyone's input from the clutch install to the cobra swap!???
Old 08-16-2017, 11:17 AM   #14
Member
Smotpoker15's Avatar
ive had good luck with my Valeo kong cobra stage 2. nice and light for street and hasnt failed me once at the track. kit is decent priced also. as far as quadrant, cable, and adjuster. i use frpp for all 3 and again very satisfied
Smotpoker15 is offline   Reply With Quote
Replace cigarette lighter assembly? How do you remove the old assembly? Abo.morris Classic Mustangs 1 10-28-2015 09:19 AM
Wanted: Clutch Pedal Assembly 03RedfireGt Mustang Parts for Sale and Wanted 0 11-24-2014 01:56 PM
Clutch assembly swap Foxresto 1979-1995 Mustang GT 0 07-24-2014 09:23 PM
Clutch pedal assembly robert81717 1979-1995 Mustang GT 2 12-29-2011 01:16 PM
Look its fast64's clutch pedal assembly steedav6builder The Bar 14 04-09-2005 10:35 PM
05:27 PM
