Hey guys. So i was driving the other day when i start to hear something banging against my car. I stop and it turns out to be rubber cut off my tire by hitting the fender.
I try pull away thinking i hit a big bump or something and when i go over a small bump to get on the highway again my rear tires slam into my fenders and jam.
I got the car unstuck and towed it home but now even the smallest bump or uneven surface causes the rear wheels to hit the car. Its like my suspension travel doubled and the wheels have no stopping point.
I havent had the chance to tear into it yet but with a visual inspection everything checks out. My first thought was a bent spring or shocks but everything looks good so far. Ill take apart tonight to try troubleshoot. Any advice on what it could be or what to look for would be a big help!
Sent from my LG-H873 using Mustang Evolution mobile app
Took the wheels off and found nothing out of the ordinary really. The only thing I saw that was weird was an indent in the passenger shock. Could that have caused this? Here's a few pics of the underside plus a pic of what the car looked like when the wheel was stuck.
Rear quarters are bent up a bit. Will have to roll and tap them back in place. Could blown shocks do the problem im having ? I always associate blown shocks with like a really bouncy ride not extra suspension travel.
The damping effect of the shock absorbers not only prevents the bouncing, but also limits, to a certain degree, the amount of travel that the suspension will experience under normal driving conditions.
With your wider rear tire/wheel setup, it is likely not bouncing because the quarter panels are now limiting the amount of suspension travel, whereas, if you had the stock 245's they would clear the quarters, and you would be going down the road bouncing like a lowrider.
It is fairly common for the shock absorbers and struts to need replacing immediately following the installation of lowering springs. It looks like yours were in need of replacement regardless of the springs.
Definitely not a bad idea to roll the fenders to provide more clearance, as well.
Update! Renting a fender roller today to fix my fenders. Have a full set of blistens coming in the mail plus some x2 ball joints. Hoping that solves the issue haha
Fender rolling was easier than I though, although a rubber mallet was equally as usefully as the rolling tool itself haha. As for my shocks AM seems to be having difficulties with their Blisten distributor because after a week they hadn't shipped. So i got a fair discount on some koni yellows. Install this Saturday.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
