Another gear question - Mustang Evolution
Old 08-16-2008, 01:27 PM   #1
01 PR RAGTOP's Avatar
Putting gears in. Going with Richmond. Leaning towards 3.90's. Question: When I'm done, the car will have about 350 to 370 fwhp on the motor, with a possible 75-100 hp shot of spray, am I going to run out of gear? Also, putting in a Richmond Powertrax (spool), anyone have one of these? Will I notice a difference between 3.73 and 3.90?
2001 GT ragtop auto, K&N c.a.i., BBK 70 mm t.b., 1" spacer, Granetelli m.a.f.,Jet Power Shifter, BBK underdrive, Motive 3.90's, Mach 1 chin spoiler, Classic Concepts light bar, Pypes off road X pipe, cryogenic treated, cross drilled and slotted rotors - ceramic pads, SCT3 custom tune, more to come.
01 PR RAGTOP is offline   Reply With Quote
Old 08-17-2008, 05:03 PM   #2
Send a message via AIM to black98gtvert
Re: Another gear question
i think you will run out of gear yes. your bottom gears will be really short. if you plan on dragging it your bottom end will be way too short. a great set of tires will help but might be too short IMO
98 GT Vert
Mods: MAC CAI,FLOWS 40 series,MSD Wires and Coils,"MM"starter box susp, MAC underdrive pullies, BBK off-road X, Steeda TRI-Ax, 3.73 gears, Sniper Special Forces Tuner, Accufab 75mm TB and Plenum, and a ZEX __ Shot
04 CBR F4i: A Street Machine on roids
black98gtvert is offline   Reply With Quote
Old 08-17-2008, 05:51 PM   #3
blk98gtvert: I know this is off the subject, but how do you like the BBK shorties? They're on my list.
Old 08-17-2008, 11:51 PM   #4
Scut95's Avatar
btw....if you plan on running the car on the street, a spool is a really bad idea....go with a limited slip or detroit locker if that is the case.
Old 08-18-2008, 06:52 AM   #5
3.73 in an auto is about right as the auto not only sucks more power but it has worse gears than the manual so... it will help make up for the difference, putting 3.73's in an auto is about like putting 3.55's in a manual (well not exactly but you get the idea)
but.. it all depends on when you run out of gear~ if you are doing quarter mile runs vs 8th~ you dont want to have to shift into another gear right before you pass the line.
Old 08-18-2008, 08:24 AM   #6
Scut95: Powertrax acts as limited slip until, you mash it, then its a locker. Thats why I'd like to know if anyone has one, to see if it works as advertised.
Old 08-18-2008, 11:00 AM   #7
Scut95's Avatar
Ok, well that should be ok then....you said spool which is both wheels locked together, all the time, bad news for going around turns......unfortunately I am not running one and I don't even know anyone who is......specter is right about the gears, it all depends on what your doing. Usually rule of thumb is 4.10's for auto and 3.73's for manual on the street but it's your call
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Gear question mystanghurts04 Pre-2005 V6 Mustang 13 08-17-2009 04:54 AM
gear question 95blackgt 1979-1995 Mustang GT 4 01-30-2008 02:58 PM
Gear question lowflyn Pre-2005 V6 Mustang 8 01-23-2006 08:29 AM
4.10 gear question oaktonarcher Pre-2005 V6 Mustang 55 10-23-2003 05:20 PM
410 gear speedo question Freds3.8 Pre-2005 V6 Mustang 23 07-21-2003 02:07 PM
05:45 AM
