Timing job a bit pricey..... - Mustang Evolution
Old 09-20-2017, 11:27 AM   #1
jkeaton's Avatar
So, I've got an occasional clicking sound on start up sometimes, sometimes lasts awhile, sometimes goes away quickly, sometimes doesn't do it at all...one of my timing chain guides is loose/broke or something we have determined. Had my daughters BF, who is a Ford service tech, look into the cost of replacing the guides, chains, tensioners, etc since they would have it all apart anyway.....
Parts alone: $705.50
Labor: 6 hours @$100 per hour....
Aint happenin...
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 09-20-2017, 11:48 AM   #2
I had a '98 Cobra that sounded like a thrashing machine upon cold start up and went away when warmed up. That was at 54K, sold it at 147K no better no worse. I just price a new GT when that happens.
Neuron is offline   Reply With Quote
Old 09-20-2017, 01:24 PM   #3
Revvv's Avatar
Aint happenin...
The last person I knew to have that job done spent a little over $1400. There is a lot of labor involved, as you already know. However, I believe you have the ability to do the job.
You will end up removing everything from the radiator to the accessories on the timing cover, block, etc, but after that the job is fairly easy.
I would make sure the tapping is indeed a timing related issue. Because the noise goes away, I have to wonder if it may be an issue with a lifter.
Old 09-20-2017, 01:25 PM   #4
Revvv's Avatar
Hopefully for your sake you find out upon further inspection that you have a simple exhaust leak.
Old 09-20-2017, 04:16 PM   #5
jkeaton's Avatar
No. Using my handy dandy mechanics stethoscope we have identified the noise as coming from the right side of the timing chain cover. Right where the guide is.
07 V6 Coupe
Old 09-20-2017, 04:17 PM   #6
Revvv's Avatar
It sounds like you have a weekend job ahead of yourself.
Old 09-20-2017, 07:06 PM   #7
Parts alone is $750? Wtf you can buy a whole low mileage PI engine for less... Either get on the FB groups or forum classifieds and get someone to sell you a set of low mileage timing stuff or go to a JY and grab a whole engine. Grab what you need and part out the rest to make your money back. Then DIY it for the price of some gaskets and a day of work. Or get this guy to do it all on the side which he can probably do way faster than 6 hours and for a lot less $$$
Old 09-20-2017, 09:45 PM   #8
phatspeed7x's Avatar
I know all about timing sets and having the 4.6L 2V motor all stripped. Done my motor like 4 times in the last 10k miles.
But that also involved a aftermarket cam swap that went south in a hurry. Ended up replacing both cylinder heads and the whole timing set.
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 09-20-2017, 10:21 PM   #9
Revvv's Avatar
My biggest reservation in those engines is the fact that you don't know what you're getting.
I have trust issues.
Old 09-21-2017, 09:31 AM   #10
jkeaton's Avatar
The timing kit alone (chains, tensioners, guides, gears) is close to $500. Then add all the gaskets, and other "consumables", it adds up quick. Yes, I could get a junk yard motor for way cheaper, but agree with Revv that you don't really know what you are getting. The pull a parts around me only have v6 cars on the lots. I know, I know, excuses, excuses, but honestly, I don't have the time or the gumption to tear into a perfectly good engine aside from a little noise every now and then. When it goes, I'll upgrade....
07 V6 Coupe
Old 09-21-2017, 03:15 PM   #11
JYs around here have a metric assload of Vic/Marquis/Towncar engines. Very populated here tho.
Old 09-22-2017, 01:30 AM   #12
I think that all of the hassle and expense of the camshaft timing components on Ford engines is the biggest reason that many people prefer to swap LS engines into various different vehicles... Including Ford's.
Old 09-22-2017, 06:18 AM   #13
Revvv's Avatar
The job is a PIA on all overhead cam engines. No matter the make, the process is about the same.
Old 09-22-2017, 07:41 AM   #14
I got employee pricing on a complete timing set when I worked at O'Reilly. Just over $200 for everything.
Old 09-22-2017, 08:57 AM   #15
Revvv's Avatar
Now you're just bragging.
I'm not sure I could put up with the incompetence of the parts store guys around me. There is ONE knowledgeable employee, and he is still in high school.
Old 09-22-2017, 11:11 AM   #16
jkeaton's Avatar
I'm getting Ford employee pricing for Ford parts.
07 V6 Coupe
Old 09-22-2017, 11:13 AM   #17
Revvv's Avatar
That could be a good thing.
Old 09-22-2017, 11:22 AM   #18
jkeaton's Avatar
No. The prices quoted are ford employee pricing for ford parts...
07 V6 Coupe
Old 09-22-2017, 11:25 AM   #19
Revvv's Avatar
In that case, that discount sucks.
Old 09-22-2017, 11:37 AM   #20
jkeaton's Avatar
Roger that...I'm sure I could go aftermarket cheaper. But, at any rate, it ain't happenin.
07 V6 Coupe
Old 09-22-2017, 12:15 PM   #21
Senior Member
dgc333's Avatar
You can get a complete set from Rockauto for a little over $200
dgc333 is offline   Reply With Quote
Old 09-22-2017, 12:44 PM   #22
Lorraine's driver
ab_mach1's Avatar
I agree!
Instagram: @ab_mach1
Old 09-22-2017, 01:03 PM   #23
Expense is not an issue if you don't mind used parts. Lots of low mileage stuff out there. Timing is easy with the degree services out there. Not on 4v but 2v yeah.
Sent from my LG-LS997 using Mustang Evolution mobile app
Old 09-22-2017, 01:46 PM   #24
jkeaton's Avatar
Dammitall!! Now you guys are going to talk me into doing this myself.....
07 V6 Coupe
Old 09-22-2017, 06:42 PM   #25
Lorraine's driver
ab_mach1's Avatar
Old 09-22-2017, 06:43 PM   #26
Revvv's Avatar
Of course we are. It's what we're here for.
Old 12-24-2017, 09:22 AM   #27
escottcarp's Avatar
Has anyone actually done this job? I have a little noise when going into 5th on a cold engine. So, I'm not ready to tackle it, yet.
But noises rarely just go away. I watched a YouTube video and there is a lot of disassembly to get to what looks like an easy job.
escottcarp is offline   Reply With Quote
Old 12-24-2017, 05:40 PM   #28
Revvv's Avatar
I haven't done a timing job on the Mustang, but I have performed the task on a Dodge 4.7 and a Hemi.
It is a time consuming job, but not hard in my opinion. Go slow, follow directions, and use a torque wrench upon assembly.
Old 12-24-2017, 06:04 PM   #29
Rapinator126's Avatar
Not a job for your average garage mechanic.
Stock motors are cheap so give it a go.
Sent from my SAMSUNG-SM-J727A using Mustang Evolution mobile app
Rapinator126 is online now   Reply With Quote
Old 12-24-2017, 07:50 PM   #30
Revvv's Avatar
I haven't found a stock motor I would call cheap yet.
(Revvv-AKA The 2V King per Recon)
Old 12-24-2017, 08:03 PM   #31
escottcarp's Avatar
I'm a Pro at taking my time on a project (to get a first-time GO!). I'd hate to disassemble so much, change parts, reassemble and find I messed up something. This can't be any more difficult than changing an axle and some of those diff components. Maybe, I'll paint the valve cover, too. Anyway, I'll be OK until the Summer.
Old 12-24-2017, 11:12 PM   #32
They are all under a $1,000, They do cost more than a 4.8/5.3 which makes no sense. Do consider them cheap $ wise, Considering I just spent $1046 On my pistons. Which were more than the ones for my coyote
Old 12-25-2017, 09:16 AM   #33
Heh, I paid $550 for a set of Diamonds brand new in box. .020 over.
As far as engines. The first 2V I had was out of a 2005 Marquis and had 38k miles. $525. The Continental 4V was $550 plus the Mach intake was $250 and the adapter was $75. Get on car-part.com and look up the engine prices around you, any 2Vs should be out of an 04-10 Panther car or if you want the WAP blocked aluminum ones you look in 02-05 Exploders but those are way way more expensive and almost all have super high miles.
Old 12-25-2017, 01:40 PM   #34
I went with Manley pistons this time 12.8 to 1. Coated and valve reliefs .30 over.
I had diamond in the yote
Old 12-26-2017, 03:55 PM   #35
Can't go wrong with Diamond. Or Manley for that matter. But couldn't pass up the deal on these. Not sure if I'll do the build or not but I'll be able to sell them if not. Benefit of having an APO address, I can ship anywhere in the lower 48 for only a few bucks more than if I was living in NJ.
Setting Timing without Timing Light ndeining Classic Mustangs 4 03-18-2014 11:12 AM
Been a bit sonic04edge Pictures and Videos 4 11-24-2009 07:46 AM
be gone for a bit Monkey The Bar 3 06-05-2005 04:20 PM
12:44 PM
