High Speed Fan Switch (94 fog light as toggle) - Mustang Evolution
Old 10-20-2017, 12:02 PM   #1
CrimsonGT's Avatar
OK Help Needed! Sorry if this has been covered somewhere else i couldn't find it.
So I have a Procharged 4V swapped 04 GT (not that is matters too much for this thread as i still use the stock GT ecu and the wire is the same pin regardless)
I need to put my high speed fan setting on a toggle switch due to some of the effects of the mods
I DESPISE toggle switches so instead I am deleting my coin holder and using a 94 mustang fog light switch as the toggle so it looks factory.
My current plan is to ground the #46 Pin ECU Wire (green wire purple stripe) by hooking it to the switched tabs (the big two) in the fog light switch and then grounding the other end of the switch using paddle connectors. I've tested with a volt meter the wires correlating to Black and Yellow in the below diagram (signal when depressed no signal when returned) (the switch is the box just to the right of the anti theft controler module)
Ideally, I would like to have the indicator light illuminated when the switch is activated and the fan is on, but More than anything I do not want to fry my ECU.
Anyone done this before?
Am I about to make a huge mistake?
I saw one person in my research stating you needed a 12v line to the Pin 46 wire but no one else stated that. Below is the generally accepted method from what i have found.
First and foremost I just don't want to fry my ECU!!
CrimsonGT is offline   Reply With Quote
Old 10-27-2017, 09:06 PM   #2
Lorraine's driver
ab_mach1's Avatar
Can’t you change the temp that the high speed fan comes on with a handheld tuner? Seems like I remember that setting in there.
Instagram: @ab_mach1
Gt Fog Light Switch Joe_Roma5 Mustang DIY and Technical 2 12-08-2014 12:46 PM
Fog light switch question? TorchRed03 Pre-2005 V6 Mustang 3 07-06-2013 08:10 PM
fog light switch Horseplay 1996-2004 Mustang GT 10 01-23-2013 07:45 AM
Headlight Fog light switch HELP!!! Fox 5.0 1979-1995 Mustang GT 11 07-08-2012 04:29 AM
98+ fog light switch Fishers Stang Mustang Parts for Sale and Wanted 7 08-26-2004 10:31 AM
08:21 AM
