Rear Pinion Seal - Mustang Evolution
Old 01-09-2018, 07:11 AM   #1
jkeaton's Avatar
Rear Pinion Seal
Leaking....gotta replace it. Searched back 3-4 years but found nothing. Anyone done this? Part is like $10-15. I'm sure a shop would add another few hundred on top of that to do it for me. I'm a pretty confident DIY'er. Any tips from the pros?
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 01-10-2018, 11:50 AM   #2
I generally farm out transmission and rear end work. But if you have a service manual and a inch/pound torque wrench, I don't see why it wouldn't be possible to do it yourself.
Really, the only tricky part is to get the pinion bearing preload set back to the original setting.
Old 01-10-2018, 12:05 PM   #3
jkeaton's Avatar
That's what I've been reading. (pinion bearing preload). Hmmm.....don't want to screw it up, but then, gotta learn somehow....
07 V6 Coupe
Old 01-10-2018, 12:28 PM   #4
Now that I'm thinking about it, if I had to choose between gambling on one of the shops in the county that I presently live in, or doing it myself... I would without question do it myself! Haha
I have a awesome differential guy... But he is 4 hours away.
The only real "tip" that I can give you is once you start tightening the pinion nut during reassembly, you can't loosen it back up.. You must tighten it and check the preload frequently to avoid over-tightening.
The worst that can happen is you won't be able to get the preload set correctly, and then the crush sleeve will need to be replaced so that the proper preload can be set.
Old 01-11-2018, 06:01 AM   #5
Coosawjack's Avatar
I've always marked the pinion nut and shaft before removing the nut.....then return the nut to the same spot for seal replacement....never had a problem doing them this way!!
Coosawjack is offline   Reply With Quote
Old 01-13-2018, 08:37 PM   #6
This is OK, as far as it goes. But, if it's done let's say 10 times this way, and one time it failed, the cost can be stupendous.....new gears, and worse.
65 k car is offline   Reply With Quote
Old 01-18-2018, 10:47 PM   #7
keeney35's Avatar
It's a really easy job but I'm an ASE master tech lol...
I never even check preload anymore I can tell if it's right by the feel..
But if you don't feel comfortable with it I wouldn't try it... not something you want to get way off.
keeney35 is offline   Reply With Quote
Rear Pinion Seal Leaking rgwest61 2011-2014 V6 Mustang 13 04-07-2018 10:01 AM
Blown pinion seal CFYA2818 2011-2014 V6 Mustang 4 12-02-2014 08:40 PM
Pinion seal leak? silverstang831 2005-2010 Mustang GT 4 06-17-2013 01:14 PM
pinion seal 2002Gt 1996-2004 Mustang GT 3 04-05-2012 06:21 PM
Pinion seal now fixed SpectorV Pre-2005 V6 Mustang 2 01-11-2005 07:19 PM
06:48 AM
