96 4.6 will not go into fifth gear - Mustang Evolution
Old 09-04-2008, 03:57 PM   #1
Have a 96 GT / 5spd that I bought and it has some gremlins. Shifting to fifth it will not go in as all of the other gears go in, if shifted hard it will sometimes go in otherwise it grinds, Linkage or bad trans ??
duals is offline   Reply With Quote
Old 09-04-2008, 04:24 PM   #2
1234's Avatar
Re: 96 4.6 will not go into fifth gear
bad syncro, is what it sounds like.
Old 09-04-2008, 09:40 PM   #3
Kiljosh's Avatar
Synchros on 5th go out all the time. I would put my money on that as well.
Old 09-05-2008, 07:18 AM   #4
Thanks alot for the info.
Old 09-05-2008, 07:49 AM   #5
Herbstang's Avatar
if you go through all gears smoothly except the 5th, it's most probably the synchronizer. how's it though when you shift to reverse?
Old 09-05-2008, 07:53 AM   #6
Herbstang's Avatar
Just a thought check that the clutch is adjusted properly by taking a look in thru the fork hole opening of the bell housing and verify the face of the throw out bearing is 1/4" away from the fingers of the pressure plate with the pedal at the rest position. If the clutch checks out and you still have grinding, the only thing left is the blocking rings and syncros
Old 09-05-2008, 08:13 AM   #7
Reverse is a little tricky also but not any where as bad as fifth. a little grinding once in a while.
Old 09-05-2008, 08:18 AM   #8
Herbstang's Avatar
5th and reverse share the same shift rail/fork that's why I asked Sounds like you'll need a blocker ring, and possibly the 5th slider you can always double clutch till you get it fixed
Old 09-05-2008, 08:23 AM   #9
Herbstang's Avatar
Just check with TKO performance they say the problem might be the sliding sleeve
5th uses a brass synchro, even on a WC T5. My guess is the sliding sleeve is torn up. Here's the trick, flip it over and use the good side, because it only works one way for 5th gear. You can do the repair by just removing the tailshaft housing. You won't affect the endplay setup, so the hard part of setting up a T5 isn't even an issue.
Old 09-05-2008, 08:27 AM   #10
Thanks for all of the info.
Old 09-06-2008, 12:06 AM   #11
yea i also have a 96, 3rd gear syncro shot now 4th following behind it. its what it is, t45 sucks man lol.
96 GT- Who knows what's in it.
HELP!! gear problem blackonblack Pre-2005 V6 Mustang 15 12-30-2009 10:03 PM
4:10 gear help The Darkside Pre-2005 V6 Mustang 8 05-27-2009 02:52 PM
Gear oil really does .... ... ... MonteCitan The Bar 9 04-20-2005 08:34 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 03:41 PM
12:09 PM
