Thermostat stuck open ?? - Mustang Evolution
Old 09-07-2008, 10:51 AM   #1
I have a 96 GT and the air didn't work so I figured that it needed to be charged, put the guage on it and it showed it to be over charged, so I let some off and it is good now but no cold air, also tried the heat and no heat!! Is it possible that the thermostat is stuck open ? Any ideas would be appreciated. The temp gauge does not move off of cold.
duals is offline   Reply With Quote
Old 09-07-2008, 03:13 PM   #2
1234's Avatar
Re: Thermostat stuck open ??
Yes it could be stuck open. But your air would still work.
So you might have a different problem. Not really sure what though.
Old 09-08-2008, 12:08 AM   #3
Scut95's Avatar
it could be that the blend door in the vent system isn't functioning properly. The temp gauge not getting off cold sounds like a stuck thermostat, but like said above the ac would still work. If the blend door isn't moving, then there is no switching between ac and heat.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Intake Manifold issue "stuck open" bigebobo Pre-2005 V6 Mustang 5 09-07-2009 01:18 AM
Need help replacing thermostat floridamba Pre-2005 V6 Mustang 1 04-01-2007 06:30 PM
thermostat? ryanxup Pre-2005 V6 Mustang 3 11-27-2006 08:17 AM
Thermostat 97conv6 Pre-2005 V6 Mustang 18 06-13-2005 06:41 PM
Thermostat Laser02 Pre-2005 V6 Mustang 14 07-08-2004 02:08 AM
09:56 AM
