4.6L V8 coolant/(pulley?) problems - Mustang Evolution
Old 09-10-2008, 04:47 PM   #1
I got a problem. the other day the large radiator to engine hose blew up and sprayed coolant all over the inside of my engine bay. My mustang is a 1999 GT and as far as i know everything was fine until the hose blew up for no reason. after i got a new hose and filled up the coolant tub with water, the radiator engine and all other parts that get heated started to smoke as the coolant was burning off. there was a high pitch squeaking or clanking noise when i press on the gas pedal. iv narrowed this problem down to a few things but i cant just be sure so i figure ill ask you guys. i cant directly tell if my engine is overheating because i think my thermostat might be broken and will only go halfway up, my check coolant light is on as well. when i started it up i noticed the water in my coolant tub was not being sucked down, almost like the engine is trying to suck water in but just cant. i had a friend who knows way more about muscle cars than me look at it and he couldn't figure it out but he did tell me that he could move the water/coolant bearing around and that isn't suppose to be good. my greatest fear however is that im going to need a new pulley because the noise i am hearing is coming from the bottom of my block. anyone have any useful tips/diagnosis they can share?
SexyLilSeaOtter is offline   Reply With Quote
Old 09-10-2008, 05:46 PM   #2
1234's Avatar
Re: 4.6L V8 coolant/(pulley?) problems
What? Ok so your water pump pulley is loose, that means you need a water pump. If your thermostat is stuck halfway open, you want to replace that too. I think you have to bleed the system.
Old 09-11-2008, 09:16 AM   #3
jimmy_beaner's Avatar
Region: Iowa
I would start with attempting to get some of the coolant off your engine first. You should replace the t-stat if you think it's partly malfunctioning (though when mine went out I got a check engine light). They are pretty cheap, and very easy to replace. In fact, I wrote up an article on how to do this on this site. It'll be a lot cheaper than trying to do the water pump.
Old 09-11-2008, 11:16 AM   #4
the squeeking is probably your idler pulley, shoot some oil on it and itll stop, happens all the time when coolant or water gets on it, the waterpump will have a little play front to back but should not move up or down, if it does then replace it....replace the thermostat period, when in doubt change it out...its too cheap, the 96-04 gts donot have a high point bleed like a cobra so the coolant talk is the highpoint, fill it with the engine running and up to temperature, your guage should be straight up and down.
if you hear a noise from the bottom, make sure your dampner is not bad and rubbing the timing cover, it is a strong possibility that it went bad.
SimplyOrange is offline   Reply With Quote
Old 09-11-2008, 12:55 PM   #5
Here is the how to for replacing the Thermostat: 1999-2004 Ford Mustang GT Thermostat Install
Coolant System nay's mustang 1979-1995 Mustang GT 8 12-23-2009 11:12 PM
Coolant level Foxone Pre-2005 V6 Mustang 3 10-13-2009 07:41 AM
what coolant hose is this? jimmy_beaner 1996-2004 Mustang GT 53 02-14-2009 10:13 PM
coolant problem......AGAIN!! NHStang03 1996-2004 Mustang GT 10 01-22-2009 05:07 AM
Coolant Leak floridamba Pre-2005 V6 Mustang 0 04-04-2007 08:40 PM
02:25 AM
