Changing coolant soon - Mustang Evolution
Old 10-11-2008, 12:33 AM   #1
and any tips guys? never kept a car long enough to need a change but mine is due one.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 10-11-2008, 07:05 AM   #2
Re: Changing coolant soon
Drain, fill, and burp.
Old 10-11-2008, 03:53 PM   #3
i think flushing might be a good idea too don't ya think?
Old 10-11-2008, 05:13 PM   #4
Kiljosh's Avatar
I just ran water through my radiator, plugged it and filled it all the way. Let the car run until it opened up and redrained. I didn't use any of that cooling system flush, heard bad things about it.
Old 10-13-2008, 07:32 AM   #5
if it REALLY needs it (more than say 25k miles between changes) I would probably drain the block as well as the radiator, there are two bolt holes generally one on each side of the block you can take out and drain coolant from.
after that the entire block should be clean, but you can run some distilled water through it to clean it out some more if you wish~ i wouldnt do tap though.
After that do a 50/50 premix fill of any time (IMO at least) and fill her back up.
You can get a shop to vacuum it and suck it through (what I did worked great) or you can just fill and get air out of it etc etc until its good just make SURE all the air is out of it.
Old 10-13-2008, 11:01 AM   #6
i've heard of using distilled water when filling it back up. sounds like a good idea seeing that you have no idea what is in tap water.
Old 10-13-2008, 11:13 AM   #7
50/50 mix you dont have to worry its distilled and ready to go
Old 10-13-2008, 10:41 PM   #8
but i'm paying only a dollar less for a bottle that is half water.
Old 10-14-2008, 07:29 AM   #9
1234's Avatar
Its easier plus it pre mixed. You might be paying a dollar less for the pre mix but your not stuck buying the gallon or so of distilled water, plus the antifreeze.
Old 10-14-2008, 08:15 AM   #10
Herbstang's Avatar
Great Point
Changing to a 4.2L? devon Pre-2005 V6 Mustang 5 09-25-2009 06:40 PM
changing my grill PenguinFan Mustang Audio & Video 6 07-26-2009 06:43 PM
what coolant hose is this? jimmy_beaner 1996-2004 Mustang GT 53 02-14-2009 10:13 PM
mind is changing... 98GreenStallion Pre-2005 V6 Mustang 25 02-10-2005 06:27 AM
changing it up theglory Pre-2005 V6 Mustang 29 01-14-2005 06:34 PM
12:18 PM
