Grinding in second - Mustang Evolution
Old 10-13-2008, 02:07 PM   #1
Grinding in second
I just recently had my tranny replaced because of the 2nd gear syncro was destroyed well the warranty company replaced it with a tranny that had 11k miles on it well im still having problems with it grinding getting into second i mean i know the suncros was out the first time but this time it just grinds could it be a clutch cable or is this a known problem?
BAgee87 is offline   Reply With Quote
Old 10-13-2008, 02:22 PM   #2
1234's Avatar
Re: Grinding in second
It very well could be. But does it do it in any other gear?
Old 10-13-2008, 03:30 PM   #3
nope just second
Old 10-13-2008, 03:33 PM   #4
1234's Avatar
Sounds like the syncros are again. If it was the cable it would do it all the time, in every gear. Try double clutching see if that helps if it does its defenitly you syncos.
Old 10-14-2008, 09:05 AM   #5
you can check the clutch cable and make sure that its fully in neutral before you shift~ check the fork and make sure its not off the pivot ball stud as well
Grinding into 3rd gear tedness 1996-2004 Mustang GT 9 01-19-2010 06:32 AM
grinding sound elystarz New Member Introductions & Greetings 1 08-15-2009 06:57 PM
Grinding Noise From Gears parkerr1 General Mustang Discussion 5 12-16-2008 05:34 PM
grinding in third?? bluestang1724 1979-1995 Mustang GT 9 02-10-2008 06:16 PM
grinding from rear gt4me 1996-2004 Mustang GT 8 11-29-2004 10:36 PM
03:22 AM
