New cams - Mustang Evolution
Old 10-15-2008, 07:54 PM   #1
ninty6stang's Avatar
Region: Oregon
New cams
Im wanting to put new cams in my pony. what kind and how much? its my daily driver so nothing to big just want something more than what i got. Also will i have change out the timing gears or can i use stock. And what is the easiest way to change them out?? thanx
96 GT PI swap, cai, 75mm tb, trick flow intake plenum, bbk tuned length headers, mac off road h-pipe, borla mufflers, stage 2+ clutch, intrax lowering springs, car still needs to be tuned..
Don't stop here this is bat country"
ninty6stang is offline   Reply With Quote
Old 10-15-2008, 08:47 PM   #2
Re: New cams
gears can be reused, and they do make a tool for the 2 valves to actually hold the sprocket in place with the valve cover removed to swap cams out. the only thing is that since u are pi swapped, the combustion chamber is alot smaller than stock, so u would have to watch the lift because piston to valve clearence diminshed when u put the pi heads on your stock npi block. comp cams are good cams, as hi tech since i have heard good things about them too. as far as cams safe to run without fly cutting the pistons, i have a list but ill have to find it.
96 GT- Who knows what's in it.
Old 11-16-2008, 04:14 PM   #3
DaDant!'s Avatar
Re: New cams
what is the benefit of swaping cams... what excatly to they improve... sorry dont know much about the mechanical aspect of engines.
00 gt:u.d. pulleys, K&N CAI, UPR O/R X-pipe, Flowmaster 40 tips
im getting there.
DaDant! is offline   Reply With Quote
Old 11-16-2008, 10:42 PM   #4
Re: New cams
well they are more efficient than the stock cams, and allow more air in and out to produce more power. some have higher lifts than other, but on modular motors you have to watch the clearance between the piston and valves. you can run stage 2 cams without problems most of the time, and u get a nice power gain, also a more aggressive idle.
New Cams? iwannagofast 1996-2004 Mustang GT 18 05-07-2010 02:30 PM
new cams COmustang 1996-2004 Mustang GT 3 05-12-2008 01:03 PM
FS: VT Cams hawks05 Mustang Parts for Sale and Wanted 9 12-28-2006 02:48 AM
Cams ridenmystang 1996-2004 Mustang GT 10 12-12-2006 06:12 AM
Cams megax29 Pre-2005 V6 Mustang 11 04-01-2006 12:07 PM
09:56 PM
