01 mustang gt questions - Mustang Evolution
Old 11-14-2008, 05:50 PM   #1
i have a 2001 mustang gt that i bought with some modifications. i'm trying to see what kind of rear end comes factory in it. is it a 8.8 or a 7.5? also what type of fluid do i need to put back in it? and i was told it has 4:10 gears in it but im not sure. so how can i tell?
johns01gt is offline   Reply With Quote
Old 11-14-2008, 05:53 PM   #2
Re: 01 mustang gt questions
What RPMs are you at at say 55 or 70 mph?
And, it comes with an 8.8" rear end stock with 3.27 gears.
Old 11-14-2008, 05:56 PM   #3
it sits at alittle over 2000
Old 11-14-2008, 05:57 PM   #4
at 70 aroun 2500
Old 11-15-2008, 12:21 AM   #5
Cobra GT's Avatar
If you are changing the oil anyway you can pull the diff cover and count your ring gear teeth and your pinion teeth and divide them to get you your gear ratio, as for the replacement oil I would use Ford oil, it probably has friction modifiers that your limited slip diff needs.
Cobra GT is offline   Reply With Quote
Old 11-17-2008, 08:16 AM   #6
sweet2kstang's Avatar
Region: Arkansas
8.8 stock
sounds like you have 3.73's (4.10's will be 3k rpm's at 80mph)
80-90 fluid and make sure the fluid has friction modifieer or you add it in
stock long block, bolt ons, and juice
N/A- 12.81@103.7
N2O- 11.79@115.8
sweet2kstang is offline   Reply With Quote
New mustang questions. jaystang13 2011-2014 Mustang GT 9 05-18-2010 08:49 AM
New 08 Mustang Owner with Questions cruss Pre-2005 V6 Mustang 12 12-24-2008 12:22 PM
New to the Mustang, I have a few Questions Renegade 800 Pre-2005 V6 Mustang 2 06-19-2008 11:26 AM
New '96 Mustang Owner has questions floridamba Pre-2005 V6 Mustang 4 03-23-2007 02:38 PM
Questions about a 67 mustang? WesR98 Classic Mustangs 6 12-30-2006 11:54 PM
08:29 AM
