crack in intake manifold - Mustang Evolution
Old 12-01-2008, 06:29 PM   #1
theres is a crack were the water coolent flows through in my 4.6 2v efi intake manifold stock.
i tried jb weld and it works till the motor hits top rpm till it starts to cut out onthe govener then it starts to pin hole leak but at lower rpm at 3,ooo it won't leak......what can i do to stop this for i don't have the money for a new intake monifold?
can i run up to walmart or autozone and get that stuff you put in the radiator to stops leaks as it says on package.
or whats yuor idea for a permanent fix to the problem other than replace part.
eddie1 is offline   Reply With Quote
Old 12-01-2008, 06:45 PM   #2
Re: crack in intake manifold
well plastic intake is hard to doctor up, heat will make the crack worse. u can source a new intake or even a used one for cheap on ebay.
96 GT- Who knows what's in it.
Old 12-01-2008, 08:15 PM   #3
its the fact of it winter up here and i don't have garage or heat source and real ust looking for something to last over the winter.
so the radiator plug stuff from autozone won't work?
Old 12-01-2008, 11:52 PM   #4
no, its actually more trouble than its worth. id try to clean the area real good and try plastic weld, they have that stuff. if not, u will have to pick an intake up.
Old 12-02-2008, 08:46 AM   #5
hottcobra's Avatar
DON'T use any of that stop leak crap. it's hell on your cooling system.
Old 12-04-2008, 10:09 AM   #6
Its a pretty common problem on the plastic intakes. i would spend the money and get a new intake
Benjytps is offline   Reply With Quote
New Intake Manifold! Chick Nasty 1996-2004 Mustang GT 21 08-12-2010 03:15 PM
intake manifold Senorjizzy Pre-2005 V6 Mustang 1 08-30-2009 01:20 AM
Intake manifold ridenmystang 1996-2004 Mustang GT 9 04-23-2007 09:45 PM
Intake Manifold 2 99'sleeper Pre-2005 V6 Mustang 4 03-07-2005 06:29 AM
95 Intake manifold. Calston31 Pre-2005 V6 Mustang 6 12-05-2004 05:42 AM
10:11 PM
