2v pi cams, valve to piston clearance - Mustang Evolution
Old 12-07-2008, 05:50 AM   #1
Cobra GT's Avatar
Can someone tell me definitely that there is sufficient valve to piston clearance on a stock 1999 and up 4.6L 2V motor with a 17cc dish piston using Comps XE270AH cams, because Comp Cams can’t? Comp Cams told me that Ford used three different piston manufactures, I think that this uninformed fellow was referring to the three different piston dish measurements of 11cc 92-98 2V, 17cc 99 and up 2V, and 3cc for 4V motors since 93. There is a lot of contradicting info on the web about this set up, can anyone please shed some light on this set up. Thank you.
Cobra GT is offline   Reply With Quote
Old 12-08-2008, 08:29 AM   #2
Re: 2v pi cams, valve to piston clearance
that cam was built for the 99-2004 2v heads, the older heads are the ones you have to watch for because they had the smaller cc pistons although i have never heard of the piston slapping on that cam even on the pre 99 cars, the lift o those cams are not much more than stock, they tnd to just increase the duration, the motors are so close tolerance that you cant put extreme cams in them anyways without running aftermarket pistons, that cam will go on your car all day
SimplyOrange is offline   Reply With Quote
Old 12-08-2008, 08:40 AM   #3
comp doesnt make a cam that will slap piston on a 99-2004 mod motor.
Old 12-13-2008, 05:59 AM   #4
sweet2kstang's Avatar
Region: Arkansas
uh yeah they do. the 270 has to be degree'd correctly to clear a 270. the 278 is huge and will have ptv issues if not maticulously degree'd. the 270 can clear a pi swap 4.6, they have to have attention to detail with degreeing them as well.
stock long block, bolt ons, and juice
N/A- 12.81@103.7
N2O- 11.79@115.8
sweet2kstang is offline   Reply With Quote
Valve to piston clearence? 93_5.0_JW 1979-1995 Mustang GT 1 04-03-2009 03:58 PM
Clearance issue? bobbyoooo 1996-2004 Mustang GT 3 01-23-2009 07:08 PM
Lowering springs and clearance UTGT 1996-2004 Mustang GT 1 06-09-2007 09:04 PM
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 02:57 PM
Need help with springs vs. tire clearance saleen0027 1996-2004 Mustang GT 11 06-07-2005 09:16 PM
08:09 PM
