2003 Ford Mustang GT
Electrical / Lighting Systems
Malfunction, happens always, always
And you said: "upgraded to blower, and built bottom end.
had cage installed, 8pt; went to pick up car and battery was dead. went to jump start my car, and then this happens.
Mach 460 Radio not working, it does get power, and you can adjust the time, and load and eject cd's, but the power will not turn on?
also windshield wipers will not move, press in on the switch to spray fluid, nothing. turn the switch to the different speed settings, nothing.
checked the fuses along the driver side dash all look to be in good shape?
also checked the fuses in the motor compartment all look good there also??
is there a central connection that these two units work off of?? that maybe was damaged during cage install? or maybe when we were jumping the battery?
also tested a few fuse locations for power, and they read as if they wern't getting any? then all of a sudden they are good..
where should i look for maybe a short? or the junction where the two problem areas come together??
radio, and wipers that is.... thanks"
