Failed Emissioni.... What to do? Catalyt ??? - Mustang Evolution
Old 07-21-2004, 06:52 PM   #1
Just did Emissions today and I FAILED>...
HC ppm Limit is 76 reading is 56 PASS
CO% Limit is 0.42 Reading is 0.17 PASS
NO ppm Limit is 605 Reading is 1163 FAIL
So what could be the problem? The guy doing the emission said it can either be the O2 Sensors, EGR valve or the Cats.
Please help
Thanks
Sig below.
NitrousGT is offline   Reply With Quote
Old 07-21-2004, 06:57 PM   #2
Is your check engine light on? Usually if its the o2 sensors bad you will see a check engine light.
Cats could be clogged. How many miles are on the car?
Old 07-23-2004, 12:38 AM   #3
No check engine light. bassani x pipe with cats are 3 years old. approx 25K miles on them
Old 07-23-2004, 12:43 AM   #4
the fact that you are missing two cats could cause your ppm limit to rise. Its not the 02 sensors or the egr valve or you would see a check engine light. My guess is its the high flow cats
Old 07-23-2004, 04:55 AM   #5
Danger Dude's Avatar
I would guess that the bassani Cats on the X pipe could be bad.
Old 07-23-2004, 11:02 AM   #6
Rick0636's Avatar
I just passed OBDII inspection with my MAC high flow H, I got it used a year old and have had it about 2 years now, of course they don't use a sniffer, its done with your computer hooked to a computer. They looked at my H pipe sort of funny, I told them what it was and that it is supposed to be 50 state legal. I have an a NC emissions sticker anyhow!
As much as Bassani stuff costs I think I would be on the phone with Bassani wanting to know why their X pipe won't pass emissions tests????
Old 07-24-2004, 10:02 PM   #7
I will call Bassani and see what they say. I dont think they will do any refunds or exchanged. I have had the X pipe for about 3 years now. I just want a short fix so i can pass the NOx ppm and drop the reading down
any suggestion?
Old 07-24-2004, 10:20 PM   #8
any suggestion?
if the cats are bad on the x pipe there is no short fix. You will need to buy two more high flow cats and put them on
Old 07-25-2004, 06:47 AM   #9
01mineralgrey6's Avatar
just get a stock h pipe to go on there(if you don't have longtubes) untill you can talk to bassani
-Tony
'99 cobra 'vert
Old 07-25-2004, 10:00 AM   #10
I concur!!!! that is the answer !!!!!
Old 07-25-2004, 04:20 PM   #11
i bout the additive from Pep Boys and it claims you will pass emissions if u use it. i am going to try it out and see how it goes. the x pipe is only 3 years old. it cant go bad already.
Old 07-25-2004, 10:38 PM   #12
crap
1998Gt blk 5spd, 2003 PI motor, mac long tubes, bbk o/r h-pipe, mac afta cats, mac cai
ScottEvil is offline   Reply With Quote
Old 07-25-2004, 10:47 PM   #13
lol you cant tell a cat when to go bad. Lots of things can make a cat go bad fast.
Old 07-27-2004, 08:05 AM   #14
Rick0636's Avatar
I couldn't swear, but I would bet nitrous might be one of those things.
Old 07-27-2004, 08:58 AM   #15
Actually Nitrous, Over rich condition can burn them out> But actually I have heard nothing but bad stuff about aftermarket Cats from My dyno guy and at tuning events. Evidently most of the Aftermarket cats our not made as good as the OEM ones
Old 07-27-2004, 07:17 PM   #16
well the car just had the head swapped to a 02 5.4L heads so i prob have to drive the car for a while to get it adjusted then it might pass emissions.
Soo...I failed. matthews.stang The Bar 18 04-24-2007 10:14 PM
Failed the gender test PureVenom The Bar 15 12-19-2006 10:03 AM
Iraq: the project that failed MarkuzLS1 The Bar 21 10-19-2006 11:58 PM
So my 89 failed inspection... MonteCitan The Bar 18 07-05-2005 10:51 PM
Emissions Test Failed robert0803 Pre-2005 V6 Mustang 4 03-03-2005 11:08 PM
09:11 PM
