what do i need to swap from auto to manual - Mustang Evolution
Old 08-12-2004, 02:15 PM   #1
Hey everyone,
i am new new to the forum and i want to do a transmission swap, i have a 97 gt and i want to swap in a manual trans. What do i need, besides tranmission, is it the T45?
Thanks
97GtStang is offline   Reply With Quote
Old 08-12-2004, 02:35 PM   #2
97Stallion's Avatar
Yes it's the t-45. You need a new computer also and the wiring harness for the tranny. You'll also probably need a new boot to go around your shifter. That should be about it.
Living one day at a time!
Old 08-12-2004, 02:37 PM   #3
clutch assembly....
Old 08-12-2004, 02:41 PM   #4
97Stallion's Avatar
Oh yeah, the pedal assembly, a clutch cable, and a clutch, flywheel, pressure plate, pilot bearing, and throw-out bearing.
Old 08-12-2004, 03:05 PM   #5
do any of you know like how much it would cost for someone to install it?
Old 08-12-2004, 03:29 PM   #6
300-400 probably
Old 08-12-2004, 04:41 PM   #7
computer, wiring harness (not sure which one exactly but probably just tranny area, for reverse lights and the little stuff), shifter, transmission, bell housing, flywheel, chain for the starter (maybe maybe not), shifter boot, shifter knob, clutch disk, clutch pressure plate, pilot bearing, fork arm, pivot ball stud, throw out bearing, tranny cross member, tranny mounts, drive shaft yoke, vss sensor (may be identical just a thought), i would change the rear mail seal on the tranny and reseal the front of the tranny and check the input shaft lash to make sure its in spec. finally 3 quarts of fluid for the tranny.
Old 08-12-2004, 05:12 PM   #8
that sounds like alot of work and hard to find......
Old 08-12-2004, 05:36 PM   #9
sell the car and buy another one, the resale value will drop like a rock, most can get a full conversion kit for 1500~ with USED tranny and probably used clutch stuff of course..... a t-45 is a pretty cheap tranny, new for around 900 bucks
Old 08-12-2004, 07:28 PM   #10
You do not need another computer.
Pull your dashpod and remove the "OD" lightbulb since it'll flash at you due to the new transmission error...it's not there anymore...
You'll also notice a slight hesitation as the EEC retards the engine for 1/2 second to allow for a downshift when you stop on the gas.
You can easily fix it with an aftermarket chip that'll remove your AOD/AODE functions.
I converted my car and have the same computer. You'll be able to run the car just fine until you get the funds to get the functions disabled.
If you decide to get another computer, there's always the resetting of the anti-theft stuff at the Ford Dealer or having it turned off with an aftermarket chip or microtuner.
Check The Ride Out... http://www.hpracing.net/mkonor.htm
Vortech SQ-2 w/2.62 pulley, Custom Stroked SSX 4.3l, G-Force T-5, SPEC 3 Clutch, Intercooler, CompuCar Nitrous Wet System, SVT Dual Fuel Pump/Tank, 42lb FMS Injectors, 90mm Lightning MAF, SCT Tuner Custom Setup by Velocity Mustang Perf, FMS 8.8 w/4.10 Gears, MAC Long Tube Headers
michael.konor is offline   Reply With Quote
Old 08-12-2004, 07:47 PM   #11
where did you buy all your stuff from?
Old 08-12-2004, 07:52 PM   #12
Danger Dude's Avatar
If you have not done a lot to your car just trade for a manual. would be worlds simpler and cheaper
Old 08-12-2004, 08:33 PM   #13
www.midwestmustang.net can get you what you need
Old 08-12-2004, 08:57 PM   #14
Go to a local scrap and/or salvage yard and get what you need. You'll save hundreds instead of buying someone's "kit".
Old 08-12-2004, 09:41 PM   #15
i would get the right computer or a chip to fix it, its getto to remove a bulb.... do it right or dont do it at all, it may very well work but its well worth it to do it right the first time, cutting corners only leads to spending more money and more worry about a problem later on. Its still a much better idea to just sell the car.
Old 08-13-2004, 08:09 AM   #16
I agree it's ghetto, but if you have to do the swap in stages, removing the bulb is alot better than putting black tape on that annoying blinking light
Auto to Manual The Darkside Pre-2005 V6 Mustang 9 10-30-2009 12:23 PM
auto vs. manual occhopperman27 1996-2004 Mustang GT 6 09-15-2009 01:24 PM
transmission swap (auto to manual) what parts? 6opka Pre-2005 V6 Mustang 8 04-02-2009 03:26 AM
Auto vs Manual Justin 1979-1995 Mustang GT 5 05-10-2006 10:15 PM
3.8 auto vs manual megax29 Pre-2005 V6 Mustang 14 10-24-2004 10:43 AM
09:38 AM
