intake question - Mustang Evolution
Old 08-14-2004, 08:39 AM   #1
intake question
hi was just wondering i bought a 99 gt now is there a different intake ie.
can i change it to a 04 gt intake or is it the same?
thanks for the help
99 sleeper vert is offline   Reply With Quote
Old 08-14-2004, 09:28 AM   #2
97Stallion's Avatar
More or less they are the same. But you can get a new intake. A few company's make them. I believe accufab makes one. It's suppose to be a little better design by increasing the volume of the intake for a better flow and can use up to a 75mm TB. Some of this I'm speculating like the 75mm TB size, but I guess you could call it a educated speculation.
Living one day at a time!
Old 08-14-2004, 01:11 PM   #3
acufab doesnt make intakes, they make throttle bodies. The only intakes available for modular gt's are the Reinhard intake, the P-51, bullet and i believe frp makes one too
1998Gt blk 5spd, 2003 PI motor, mac long tubes, bbk o/r h-pipe, mac afta cats, mac cai
ScottEvil is offline   Reply With Quote
Old 08-14-2004, 02:50 PM   #4
97Stallion's Avatar
yes they do. Ahh, poor newbie......
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Old 08-14-2004, 02:54 PM   #5
you never clarified upper intake plenum, you said intake . And I am not a newbie bro, only here at this forum .
Old 08-14-2004, 03:02 PM   #6
97Stallion's Avatar
gees, don't get your panties in a knot, I was just messing with you. And a plenum is another word for an intake. You have 2 intakes like everybody else, and upper and lower. So if you get a new upper plenum, you're getting a new intake, same thing.
Old 08-15-2004, 07:36 AM   #7
ok well i guess im looking for the lower intake then notr the plenum plan for a c&l plenam and t/b but there was a recall one the lower intake something about the attachments for the alternator but do they just put some new pieces on it or do u get a new intake
Old 08-16-2004, 11:56 AM   #8
The lower intake is plastic so it is all one piece. there is no performance increase between the 99-04 intakes. UPPER Intakes And Plenums are the separate parts. They choices for LOWER intakes is limited and very expensive. The UPPER intake is where you should focus on more being that is where the restricction starts. You UPPER can only supply the LOWER so much. CAI and Throttle Body and Plenum is where you should start. If you do the lower first and do nothing else to compensate you may hurt performance not help it! I hope I listed everything right....I wouldn't want to get yelled at!hahaha
Ted
I pity the fool!....
2000 Ford Mustang GT Convertible Silver w/ Black Leather and Mach 460 Automatic
Performance:Magnaflow Exhaust, Transgo Shift Kit,Modified Air Box Looks: Grille delete, 17x9 polished 95 Cobra R's, New GT Hood Scoop, Billet Shift knob, Custom Shift Boots
Sound: Alpine CDA-9835, Infinity Reference Comp.
Power Tour 2005 Here I Come!
Funky4.6VERT is offline   Reply With Quote
Old 08-16-2004, 12:39 PM   #9
Rick0636's Avatar
The aftermarket upper intake plenums, unless I am mistaken, will only work with the stock lower intake, the aftermarket intakes wouldn't work with them at all, and the bullet intake works with a cobra plenum and t bodies I believe, so it wouldn't be any good with the after market upper intake plenums either, so if you plan to go with the expensive lower intakes, then you might as well forget the upper intake plenums. Oh, and the Accufab upper intake plenum while nice looking and expensive, and will work with a 75mm tbody, is only designed for a 70mm maximum. The other available ones are all designed to take a 75mm and are considerably less money.
Old 08-17-2004, 08:38 AM   #10
well thanks for the info guys
1998 gt intake question eddie1 1996-2004 Mustang GT 6 03-02-2009 09:07 PM
Intake Manifold Question. ricksmastermix 1996-2004 Mustang GT 9 02-18-2009 07:43 AM
combo/ intake question trickflow211 1979-1995 Mustang GT 0 11-16-2008 11:46 AM
question 99- intake on 01? thirstymate The Bar 7 08-12-2004 10:48 AM
ported intake question Zim Pre-2005 V6 Mustang 16 03-14-2004 10:24 PM
05:42 AM
