Fuel Additives - Mustang Evolution
Old 01-02-2009, 09:10 AM   #1
Fuel Additives
How do you guys feel about fuel additives (octance boosters, fuel injector cleaners) and oil additives like zmax?
redGT773 is offline   Reply With Quote
Old 01-02-2009, 09:41 AM   #2
1234's Avatar
Re: Fuel Additives
Most are useless. There are a couple brands out there that do work. I have used Lucas injector clean for about a year in my old ladies car, and have noticed a gain of 2 to 3 mpg. I dont use octane booster none seem to work. Or its just cheaper to run the better gas. Ive never used an oil additive.
Old 01-02-2009, 10:06 AM   #3
hottcobra's Avatar
Re: Fuel Additives
anything lucas makes is liquid gold. most if not all of the octane boosters are worthless. people have raved about seafoam for years, but never really used it.
Old 01-02-2009, 10:14 AM   #4
Scut95's Avatar
Re: Fuel Additives
I've used seafoam to "clean out" my engine. Don't really know if it worked but it's easy and cheap to do. If it makes you sleep better just do it.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 01-02-2009, 10:51 AM   #5
MonteCitan's Avatar
Re: Fuel Additives
As for fuel injector cleaner, never found anything that worked better than the type that you pressurize and connect to your fuel line, disabling the fuel pump - and running the engine off of that alone - never noticed a performance or gas mileage increase using any in-tank 'fuel injector cleaners'
However, Ford does recommend using chevron techron on the 05+ mustangs when they have fuel gauge/sender problems, and it did seem to cure the problem (at least temporarily), so they must do something, even if minimal
as for octane:
Octane Booster Reviews
That links to a site I found very useful when setting up a track tune when I didn't feel like wasting $ on race fuel - plus it was readily available when I was tuning, race fuel was only available about 30 minutes from here -
I was able to add ~1.5* timing across the entire RPM range using a slightly higher than recommended dose of Torco -
Also, another link.. this can be found in the form of paint thinners at home improvement stores.. (toulene and xylene)
Homebrew Octane Boosters
Hope this helps some..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-02-2009, 10:52 PM   #6
Re: Fuel Additives
Yes that does help thanx for the imput. Has anyone tried that zmax stuff it supposedly makes your oil easier to obsorb into the metal, i don't know about metal and its capability to obsorb lol. it says also it can incrreas your hp by 3or 4.
Old 01-02-2009, 10:55 PM   #7
MonteCitan's Avatar
Re: Fuel Additives
I would trust running royal purple for engine protection/a few extra HP over zmax, I've NEVER been a fan of oil additives
Old 01-03-2009, 03:28 PM   #8
Re: Fuel Additives
about the only things I add are fuel injection cleaner every oil change and maybe you can seafoam the car~
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Not getting Fuel!!! Blt4dtuff 1979-1995 Mustang GT 5 05-29-2008 03:43 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
Fuel.. etc. Laser02 Pre-2005 V6 Mustang 3 11-16-2004 09:10 PM
04:22 AM
