head work - Mustang Evolution
Old 01-03-2009, 12:29 PM   #1
Talking head work
i need to replace the valve stem seals. have read somewhere before that the seals go bad about 130k on these engines. mine has 140k...i'm fairly good with a wrench, so i want to do it myself. anyone have a write up on doin this & exactly what tools i have to have? far as i know it can be done with the heads still on the engine. would appreciate any help guys. thanks...
white98gt is offline   Reply With Quote
Old 01-03-2009, 08:05 PM   #2
hottcobra's Avatar
Re: head work
is the car smoking? are you burning oil? If not if it ain't broke don't fix it
Old 01-04-2009, 06:44 AM   #3
Re: head work
yeah, it's smoking when i take off from a stop. smells bad, oil, not a coolant smell.
Old 01-04-2009, 12:25 PM   #4
hottcobra's Avatar
Re: head work
well to answer your question. your gonna need the tool to lock the cam gear in place so you can remove the cam. than your gonna need a comp. tester hose so you can pressure the cylinder with shop to hold the valve in place when you remove the valve spring. and last you will need a valve spring compressor tool to remove the valve springs, also you will need a pencile magnet to remove the valve locks. It's not an easy job but you can do it in a days time. also if you plan on camming the motor in the future I suggest upgrading the springs and retainers while they are out
Old 01-04-2009, 02:33 PM   #5
Re: head work
u can also source out a set of pi heads for cheap and just swap the heads and intake to fix the oil problem and also add a lil power, just my .02.
96 GT- Who knows what's in it.
Old 01-04-2009, 02:47 PM   #6
hottcobra's Avatar
Re: head work
^true just a little more involved
Old 01-06-2009, 03:33 PM   #7
Re: head work
thanks for the help guys. would rather find pi heads & intake, but kinda scarce around here. no wrecked stangs in the bone yards. what's an average price to pay for those things?
Old 01-06-2009, 03:41 PM   #8
Re: head work
well there is a guy that parts out stangs by me and i paid a really good price for the heads and intake. there is a set on sale right now on sn95forums.com, u can check it out. if u are looking into parts let me know.
Old 01-06-2009, 03:43 PM   #9
Re: head work
cool. thanks man. income tax will get that stuff, just was wondering what kinda money i'm looking at.
Old 01-06-2009, 04:17 PM   #10
Re: head work
btw, will my valve covers work on the pi heads? cam gear? guess i'll start getting a list together...
Old 01-06-2009, 08:50 PM   #11
Re: head work
make sure u have either the romeo or windsor engine, im pretty sure u should have the romeo. u can check your vin to make sure, then get pi parts for the same line engine ie- romeo npi -romeo pi. that way u can reuse your vavle covers etc. the parts to do everything shouldnt cost u no more than 4-500.00.
head problems.. need help please b's stang New Member Introductions & Greetings 16 12-14-2009 07:41 PM
<head></head> Earings Brent The Bar 10 06-02-2007 12:48 PM
head gaskets railblazer82@ya Pre-2005 V6 Mustang 6 02-13-2007 06:00 PM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 07:52 AM
Head 2 Head battle Angel The Bar 14 08-11-2003 10:29 PM
05:56 PM
