starter issue? - Mustang Evolution
Old 01-04-2009, 11:33 AM   #1
jimmy_beaner's Avatar
Region: Iowa
starter issue?
Starting on Wednesday... when I tried to start my car, all I would get is a *click*. Now, I checked the battery... that isn't the issue. Even working off a running 4x4 truck did NOTHING... still *click*.
So, Friday... I push start the car with my dad. It runs just fine. I drove it to a shop 80 minutes away, and drop it off for them to replace the starter. They call me about an hour later saying "we can't find anything wrong with your current starter... we've started it 12 consecutive times without issue"... I said hmmm.... and took the car home. It started well the other 5 times I had to start it that day. Well, yesterday I go to move it from a spot to a more open one so I could work on the o/r x-pipe I have... and *click*... so I call my buddy over and I go "listen to this ****.... *VROOOM*" fires right up. Now I'm sitting here going ::
So I go out there this morning *click*... I'm getting pissed off and I'll probably end up just replacing the starter and saying "I'm done with it". But I would like to know what's wrong...
So... what would cause temperature sensitivity on the starter? Yesterday all I did was give a healthy push back and drop the clutch with the car in reverse and it seemed to "pop" it out of being stuck? And then it started ok. We got ice last night, so I'm not sure I'll be able to give it a push or not.
Old 01-04-2009, 12:13 PM   #2
Region: Iowa
Re: starter issue?
little update... I put the heat gun at 1350 degrees and blasted it on the starter for 3-4 mins... and the car fired right up... what is WRONG?!
Old 01-04-2009, 01:05 PM   #3
Re: starter issue?
Has it been really cold up there? Your solenoid could be frozen.
Old 01-04-2009, 01:22 PM   #4
hottcobra's Avatar
Re: starter issue?
it is for sure a bad starter. I have had them go bad in cold weather down here, and it doesn't get as cold down here as up their. with age the starter and sol. builds up trash inside if it that turns into a gunk and freezes in cold temps. and causes it to stick. replace the starter and check the cables for good measure and your done
Old 01-04-2009, 01:53 PM   #5
bobbyoooo's Avatar
Send a message via AIM to bobbyoooo
Re: starter issue?
i had a similar problem sometimes it started sometimes it gave me the clicking noise... for me it was the theft system malfunctioning, the light blinks rapidly and when u try to start it it made the noise i just keep turning the ignition till the light stops blinking, idk if that helps u just lettin ya know
<a href=http://i364.photobucket.com/albums/oo82/sicotickiller/mustang-2.jpg target=_blank>http://i364.photobucket.com/albums/o.../mustang-2.jpg</a> <--- click for exhaust clip
01 gt AUTO mods: MAC LT headers, O/R prochamber, borla mufflers, eiback pro kit 03 cobra rims still to come: K&N CAI, BBK 75mm TB, Steeda ud pulleys
"spendin money that I don't have to buy parts that I don't need to impress people that I don't know who prolly don't even care...."
bobbyoooo is offline   Reply With Quote
Old 01-04-2009, 04:53 PM   #6
Region: Iowa
Re: starter issue?
yeah, the PATS isn't the issue. I'm gonna call some shops and see what I can do. Luckily I know I don't have to push start it now... just get out the heat gun. I figure at 126k miles... some **** is bound to start breaking.
Starter not working? blue-saleen Pre-2005 V6 Mustang 7 07-19-2010 08:48 PM
Starter noise maxxx Classic Mustangs 2 10-15-2009 09:22 AM
starter 95gt45 1979-1995 Mustang GT 5 05-30-2008 06:53 PM
Starter..Altenator..or both? MuStAnGcHIk88 Pre-2005 V6 Mustang 5 12-03-2007 08:36 PM
Starter wkndpaintballer Pre-2005 V6 Mustang 21 03-01-2007 02:21 PM
06:57 PM
