mustang 4.6 interchange - Mustang Evolution
Old 01-09-2009, 02:54 PM   #1
Region: West Virgina
Hello all,
I am new to this site,but here goes I have a 1998 mustang gt with a 4.6L sohc engine in it will a 1999 mustang gt 4.6L engine work in my 98 mustang with out to much problems.My 98 is a 5spd and has air cruise and tilt wheel if that makes a difference. email me back at autolover70@yahoo.com
luvmystallion is offline   Reply With Quote
Old 01-10-2009, 12:10 AM   #2
Re: mustang 4.6 interchange
the engine will go in with no problem, use all the electricals off the 98 on the 99 motor and u may need a tune to take advantage of the pi engine. its a straightfoward swap.
96 GT- Who knows what's in it.
Old 01-10-2009, 09:54 AM   #3
there will probably be some electrical connection issues but overall its not to bad of a swap so they say
Old 01-10-2009, 08:01 PM   #4
so what do you mean tune?,do I have to take the car and have the computer flashed
Old 01-10-2009, 10:34 PM   #5
The changes you will be making will be too much for the factory computer to compensate for. So you will need to have the car tuned for the new setup to run efficiently and correctly.
Old 01-11-2009, 10:05 AM   #6
Will it help if I chipped the computer.
Old 01-11-2009, 10:53 AM   #7
hottcobra's Avatar
no you need a real tune
Old 01-11-2009, 11:05 AM   #8
so I need to find somebody that can tune it with a laptop to compensate for the other engine .
Old 01-11-2009, 11:06 AM   #9
I live in a rural area in WV there is not alot of shops if any that can tune a car with a laptop to compensate for the newer motor
Old 01-12-2009, 03:18 PM   #10
yea ure gonna need a real tune. there isnt any electrial issues when u swap the motor, this i know for a fact. just use all of your electrical parts off the 98 on the 99.
Old 01-24-2009, 01:58 PM   #11
jwyche's Avatar
Hello all,
Here's a site that might answer all your questions. The article is titled Modular Mix and Match. Modular Mix & Match, Part 1--Muscle Mustangs & Fast Fords Magazine
I'll send it to your email as well. Good luck on your car.
Jim
Jim Wyche:Senior Citizen. 1992 Mustang GT with a few mods. See webpage http://web.mac.com/jwyche or my garage. 2002 Mustang GT with a few mods. Collegedale, Tennessee.
jwyche is offline   Reply With Quote
Old 01-24-2009, 02:12 PM   #12
jwyche's Avatar
Hello all,
Jim
Old 02-09-2009, 06:31 PM   #13
thanks for the info guys still haven't really messed with the car much,it's winter here and all but I did find someone here locally that can do a computer tune and flash the original computer .He's into these engines but in the trucks.He has a lightning that he drag races and it's so fast thats he's run himself out of his class.The next class up mandates a rollcage in the truck and refuses to cut up the interior of his lightning,so I figure if anyone can do it he can.By the way if there are any of you guys/gals out there close to Covington Va his buiseness is called Troyer Performance.But I will not need the 99 wiring warness witch will probably go up for sale complete with the coil on plug stuff too.By the way can I use the injectors that are in the 99 model motor.I really got a good buy on this motor just needs a rist pin.Gave $200 for it
Old 02-09-2009, 09:32 PM   #14
u will have to keep your existing injectors because they are different. they are both 19lbs but one is an ev1 and the other ev6. wont interchange without plug adapters that i seen for sale or modifying the harness.
Old 02-10-2009, 05:00 PM   #15
DaDant!'s Avatar
they have the adapters on american muscle.
00 gt:u.d. pulleys, K&N CAI, UPR O/R X-pipe, Flowmaster 40 tips
im getting there.
DaDant! is offline   Reply With Quote
Old 02-10-2009, 05:32 PM   #16
jwyche's Avatar
While on the topic of the 4.6, I'm redoing my 2002. Do you know of anyone who has used an electric water pump on the 4.6 and what their results were?
Jim
Old 02-10-2009, 05:48 PM   #17
Jim
I would think the gains would be minimal. You also have to decide if you will be running a greater risk of something going wrong (wires chafing, ground coming loose, fuse blowing) which will lead to and engine going bye-bye very soon.
With that being said...I'd do it if you're pulling everything out anyway. Might only be worth 3hp but it's 3 more hp than you had to begin with.
Old 02-10-2009, 06:03 PM   #18
jwyche's Avatar
They claim 12 HP but the possible screw-ups you mention are entirely possible with my mechanic work! Besides, those things are expensive!
Jim
3.8 year interchange Southernplayer Pre-2005 V6 Mustang 4 01-06-2006 08:40 AM
More Axle Housing Interchange Qs ?? FUNK 49 Pre-2005 V6 Mustang 9 01-17-2004 12:43 PM
02:08 PM
