pi swap aggitation... - Mustang Evolution
Old 01-09-2009, 08:32 PM   #1
Question pi swap aggitation...
been doing alot of reading on the pi swap. finding out more & more that i didn't know about. some say the crank & cam bolts need to be replaced. this true? also read that these bolts are tty like the heads. true? i'm guessing the exhaust manifolds from my car will work. seems to be a pain in the *** in rounding up the small items...i saw where parkway ford has a complete kit for around 1400.00. minus the heater tube & water pump nipple... also, do i HAVE to get a tune when all this is done? no tune shops around here. you guys that have done the swap, is all this worth it? maybe i should just look for a complete engine. i need some input from you all, good, bad, & the ugly truth. thanks guys...
white98gt is offline   Reply With Quote
Old 01-09-2009, 08:47 PM   #2
MonteCitan's Avatar
Re: pi swap aggitation...
Cam bolts don't have to be touched if you get heads with assembled heads (IE PI heads removed and sold as a whole) Also I believe they are TTY, but I also recall seeing somewhere APR makes a set that are not TTY, even if the bolts are torque to yield, it's not too difficult.. torque to proper spec, then turn a set # of degrees
crank bolts don't need to be touched unless you're replacing the crank for some reason -and I would say.. you could run the car without a tune, it'd probably handle it fine, OBD II adjusts fuel and timing based off of air/fuel (O2 and MAF ) BUT in your case its' basing it off the non PI motor, so you would get the best gains with a tune, for sure
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-09-2009, 08:55 PM   #3
thanks man. reason i said crank bolt is i was thinking about changin the timing chains while i was at it... oh yeah, it's got 140k on it..
Old 01-09-2009, 09:08 PM   #4
MonteCitan's Avatar
Timing chain should be fine, wouldn't hurt to replace the tensioners while you're in there, though, those fail a lot more often than timing chains
The balancer is coming off regardless to get the timing cover off, you don't have to touch the crank bolts in either case (just the one going into the crank for the balancer - that's NOT tty)
Old 01-10-2009, 12:08 AM   #5
the crank bolt is about 7 bucks or so from ford and the nipple was about the same price. u would really benifit from the tune but i am running without one now and im running rich as hell and its been about a year. get the head assemblys with the camshafts, the ford racing head changing kit because its the cheapest set ull find for it. it comes with head gaskets, head bolts, dipstick tube, and exhaust manifold gaskets. ull need to buy the timing cover gasket set, valve cover gaskets and the intake gaskets. i did the swap myself, so if u need help, let me know man.
96 GT- Who knows what's in it.
Old 01-24-2009, 01:47 PM   #6
jwyche's Avatar
If you find a better price on ARP 4.6 head studs than $470.00, would you mind posting it?
Jim
Name:	2002 GT Passenger side medium.jpg
Jim Wyche:Senior Citizen. 1992 Mustang GT with a few mods. See webpage http://web.mac.com/jwyche or my garage. 2002 Mustang GT with a few mods. Collegedale, Tennessee.
jwyche is offline   Reply With Quote
4.6 swap to a 5.4 b's stang 2005-2010 Mustang GT 9 06-21-2010 09:26 PM
4.6 - 5.4 swap bruyn 1996-2004 Mustang GT 19 01-21-2010 06:25 AM
5.0 swap into a 79 2.8 01mineralgrey6 1979-1995 Mustang GT 22 04-19-2007 11:29 AM
Any of you swap a V8 from a V6? 97Stallion 1979-1995 Mustang GT 9 11-08-2005 11:31 AM
t5 swap powerhungry966 Pre-2005 V6 Mustang 7 10-19-2005 08:18 PM
11:39 PM
