Car idles then dies - Mustang Evolution
Old 01-13-2009, 05:49 AM   #1
Car idles then dies
I have a 00 GT (auto) and for some reason it likes to just idle down and die. As long as the RPMS are up the car has no issues.
Problem usually happens in the morning with Heater On and Headlights.(its cold in LA in the morning 5amish)
Mods:
Flow Master Exhaust pipes
BBK Intake
BBK TB 70mm
GMS Ford 2V Hot-Street Coil Pack
Optima Redtop
Audio:
Pioneer Indash
Also have a right turn signal out. (waitin till tomorrow because I have no headlights being delivered.) just replaced the serp belt with a ****ty gatorback from autozone.
Now once the car completly warms up and sits for awhile it seems like the rpms go from a crappy 400 idle to a strong 700 idle.
Do you think maybe its a MAF sensor or a MAP sensor?
I do not have a predator or anything to read codes until later 2day (maybe) or tomorrow. Still waitin on UPS.
Anyone have any ideas?
Yes I searched Prior to posting but its still early .
2kslvrgt is offline   Reply With Quote
Old 01-13-2009, 06:00 AM   #2
Re: Car idles then dies
Quick note. Iam going to try n clean the IAC if that doesnt work I might just replace it.
Old 01-13-2009, 07:09 AM   #3
The IAC is my guess, especially now that the weather has turned cold. They tend to mess up in colder weather more often. I personally would replace it, the last thing you want is to be in the middle of taking a corner and your car die... guess what no power steering.
Old 01-13-2009, 12:28 PM   #4
Herbstang's Avatar
To check your IAC:
Startup the car, and unplug your IAC while it's idling. If it tries to stall or runs rough, it is working properly. If it runs the same, it's bad
Old 01-13-2009, 12:38 PM   #5
hottcobra's Avatar
If the IAC is not the issue. check for any vac. leaks
Old 01-13-2009, 12:50 PM   #6
my iac was hit and miss, it would work then it wouldnt. just keep an eye on it
When car starts, idles to almost kill... Cajun JungleBoy 1979-1995 Mustang GT 29 07-25-2008 08:33 AM
Famed car builder Lil John Buttera dies HisPony General Car Discussion 4 03-03-2008 09:43 AM
Car dies after driving with a/c on??? username182 1979-1995 Mustang GT 8 06-21-2005 07:10 PM
Sports Car Developer DeLorean Dies at 80 Seph The Bar 14 03-21-2005 05:52 PM
Reagan Dies at 93 LuvMyGT The Bar 21 06-07-2004 12:30 PM
08:35 AM
