Need HELP!!!!!!!!! - Mustang Evolution
Old 01-13-2009, 09:08 AM   #1
allnotch's Avatar
Need HELP!!!!!!!!!
I have a 02 gt, 5 speed, 115 on the clock and the other day I down shiftied andgot on it hard and when I came the red light it was missing really bad so I had it checked and the number 3 cyclinder was missing so I replaced the coil and plug( and the plug was flat but no marks like anything hit it) and the car ran fine for 2 days and it did it again but this time it was number 4 so I replaced the coil and all the plugs and it still does it and when I pull the wire off the coil or the injector the motor dont change.
allnotch is offline   Reply With Quote
Old 01-13-2009, 09:25 AM   #2
hottcobra's Avatar
Re: Need HELP!!!!!!!!!
you need to start with a comp. check
Old 01-13-2009, 10:43 AM   #3
MonteCitan's Avatar
Start with the easiest - in my time as a tech I've gotten brand new coils, out of the box, that were bad - try swapping that coil with a known good one, see if it still has a miss.. If it does, and there's no circuit codes stored (IE if there were a wiring/connector issue, it would show a code for that coil..)
Ditto what hottcobra said.. Regardless if it looks like something hit the plug.. something closed the gap, so there was some sort of contact somewhere.. A closed gap on a plug in the regals like mine is a sure sign of a chipped piston (hypereutectic... HARD but brittle, just takes some spark knock) and if I remember right Ford left out the knock sensors on the 99+ mustang GTs.. While you're probably still naturally aspirated, a lack of fueling could definitely cause detonation, audible or not..
If you go ahead with a compression check, let us know what you find out.. Could be a broken spring/etc...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-13-2009, 12:16 PM   #4
allnotch's Avatar
Well had it looked at and number 3 is fine but 4 has no compression he also said maybe valve spring, so I going to rip the vavle cover off, I'll check back in a few.
Old 01-13-2009, 12:40 PM   #5
hottcobra's Avatar
check for a broken valve spring. if that's not it. you need to do a leak down test, to find where it's at.
Old 01-13-2009, 02:03 PM   #6
allnotch's Avatar
Ok well the valve spring is good so what now? Valve? I dont have the time or the tools to pull the head myself since we moved to Texas from Florida and this shop said like $600 for labor plus parts and I just dont feel good about messing with the timing myself.
11:47 AM
