REAR MAIN - Mustang Evolution
Old 01-20-2009, 02:09 PM   #1
REAR MAIN
anyone ever change the rear main on there 4.6L motor and if so how did it go? Was it easy? What all was required? etc etc
2kslvrgt is offline   Reply With Quote
Old 01-20-2009, 03:07 PM   #2
Re: REAR MAIN
I think you have to drop the transmission and then lower the oil pan in the back to get to it.
Old 01-20-2009, 05:04 PM   #3
hottcobra's Avatar
Re: REAR MAIN
yes you have to remove the trans. and flywheel. lower the rear of the oil pan to replace the rear main seal. it's not very hard, but you it has to be done right or it will leak again. If you have a 5 speed go ahead and replace the clutch while your in their. It's about a 6 on a scale of 1 to 10 on how hard it is. It is an all day job for your first one.
Old 01-20-2009, 07:07 PM   #4
Re: REAR MAIN
its also a one piece seal thats on a plate that bolts onto the rear of the engine block. like stated before u gotta drop the tranny and remove the flywheel and clutch, then after u take the flywheel out u will see a plate that surrounds the rear of the crank that has 6 bolts holding it onto the rear of the block. remove the bolts and kind of wiggle it away from the engine and it will come off. knock the seal off and tap the new one it then lube up the seal in the inside with a little oil and gently push it on the back of the crank and bolt that piece back on. u dont have to tighten it like crazy, id get the torque specs to be safe. i did mine and it wasnt too bad, the seal was a piece of cake once everything was out the way. if u are doing it yourself make sure u have someone there that can help u out when u need it
96 GT- Who knows what's in it.
Old 01-21-2009, 04:23 AM   #5
Re: REAR MAIN
Thanks. Will be doing it this weekend. Shouldnt be 2 bad.(its exactly as I though it was going 2 be)
New Main Page Brent ME Site Help & Announcements 12 03-18-2005 09:11 PM
Main Page? Ibanezplayer272 The Bar 20 06-03-2004 08:03 AM
main site update??? KrazyPony ME Site Help & Announcements 5 05-06-2004 01:21 PM
Main page for my site n8r The Bar 12 10-10-2003 01:10 PM
11:37 PM
