Need instructions on how to replace seatbelts - Mustang Evolution
Old 01-26-2009, 03:53 PM   #1
midnight02's Avatar
Question Need instructions on how to replace seatbelts
Can anyone give me step by step instructions on how to replace my seatbelts on my 02 Mustang?
The drivers side seatbelt will not retract and I keep slamming it in my door, and the passenger side seatbelt wont come out at all. I have the replacement seatbelts already I just need to know how to put them in. I realize that I will have to take out some panels and possibly the back seat, and this would be included in the labor costs if I took it to a dealership to get fixed. Apple Ford told me $280 per seat belt! 2::
midnight02 is offline   Reply With Quote
Old 01-26-2009, 04:04 PM   #2
Re: Need instructions on how to replace seatbelts
It's gonna be a PITA....I do not have a write-up for a 99-04. Let's see what I can find though...
Old 01-26-2009, 04:24 PM   #3
midnight02's Avatar
I would really appreciate it
Old 01-27-2009, 07:15 AM   #4
Herbstang's Avatar
Here's something I found that might help ya
Remove the back seat. The bottom is held in by a push button latch about 10 inches in from each side. Use a flat blade screw driver to push in the button. Remove the bottom. The back is held in with 2 18mm nuts. Remove nuts,pull out and up to remove seat back.
On the panel,remove the top speaker cover,it is held in with clips. remove the T bar between the speaker cover and seat belt. The side panel is held in the rear by 2 plastic studs that are where the seat back rests,and 1 platic stud on the top edge. The front is held in with 2 little trim studs that are in the weather strip. After these are removed,pull the panel towards the front. It has 2 metal clips holding it to the body.
Once it is off the seat belt is right there
im about to replace my clutch/flywheel what else should i replace? 1996v6stang Pre-2005 V6 Mustang 2 07-12-2010 11:22 AM
New Seatbelts cost What!!?? at7311 General Mustang Discussion 6 09-15-2008 08:37 AM
Why you wear seatbelts!! at7311 The Bar 14 07-24-2008 01:54 PM
Seatbelts meteorachick Pre-2005 V6 Mustang 14 01-18-2007 09:14 PM
Help no instructions mohrnormal Mustang Audio & Video 3 02-11-2005 08:52 PM
01:12 AM
