1996 GT has been modded - hp/tq? - Mustang Evolution
Old 09-28-2004, 10:13 PM   #1
I am wondering about torque/hp ratings my bro can expect
My brother has a 1996 4.6L GT.
mods: K & N, 32 valve??? Upper intake (not sure how this works, but he had the stock one replaced with another one when it was in for recall), Duals with 2 hi-flow cats and Flomaster 40 series mufflers.
Does anyone have a similar setup, and know what HP/torque range we are sitting in? Also, if someone would like to explain the ui situation....
Thanks...my first post here (i used to post at 232stangs yay!)
-silverspeed
http://www.mustangmods.com/data/1581/sig3.jpg
Check out my car on cardomain!
CAI (99+), 17" 01' GT rims, Hankook hrII tires, interior switch pony, dressed up engine (blue), other numerous appearance mods
Sil\/erSpeed is offline   Reply With Quote
Old 09-28-2004, 10:28 PM   #2
Let me elaborate... I am his bro, and decided to join in hopes of shedding some light on my new car. I just got it a little while ago, and from the past owners description, when his radiator blew it affected the top portion of the motor (Intake Manifold?). He had to get it replaced. Well, he had a family friend who worked at a performance shop and instead of putting back on the stock 16v stuff, the guy installed stuff from the 32v cobra engine.
I guess my questions are: Is this possible? If so, what horsepower gains? What exactly can be transplanted from the 16v to the 32v?
The car felt much faster than other GT's I drove with only exhaust and CAI. It has stock gears in it, so that is ruled out.
96GTwhite is offline   Reply With Quote
Old 09-28-2004, 10:30 PM   #3
Rick0636's Avatar
Well, its just a 16 valve, not a 32 Valve, sorry. Only Cobras have 32 valves. Not so sure on that upper intake, he might have a C&L, Dragon, Trickflow, etc, they all add a few horses, the high flow cats will add a few, flows just add noise really, stock mufflers flow as good or better. The best way to get more horses from that engine is to put PI heads and intakes from a 99+ 4.6 on it, that is an instant 40 hp or so. Right now, it was stock at about 225, so he has maybe 240 max, probably not that. I am sure it sounds good though.
Old 09-28-2004, 10:31 PM   #4
01mineralgrey6's Avatar
my buddies 97 i wanna say blew the lower intake manifold apart...but anyway, its possible that someone did a head swap on it, and put the DOHC cobra heads on it, but i belive you would have to change the intakes as well.Im not sure... do you have any pics of the motor? welcome to the site by the way
-Tony
'99 cobra 'vert
Old 09-28-2004, 10:33 PM   #5
yah, I will take some for you guys tomorrow when i go back home. That will help i am sure.
Old 09-28-2004, 10:33 PM   #6
Rick0636's Avatar
I wouldn't think a Cobra intake would fit really, but I suppose it might be possible, sounds like BS to me though. If it came off a cobra it would be Aluminum, if its the stock one its plastic.
Old 09-28-2004, 10:35 PM   #7
Rick0636's Avatar
quick check for ya on that, Cobra intakes have dual throttle bodies on them.
Old 09-28-2004, 10:45 PM   #8
Hm, well that is wierd that he would BS me like that. Yah, it is a black top manifold, and it doesn't have the cobra on it. Thanks for the help.
Old 09-28-2004, 11:00 PM   #9
pictures would def help... cant you ask him what parts he changed over?
Old 09-29-2004, 06:45 PM   #10
Get some pics~!!!
Old 10-03-2004, 08:52 PM   #11
If you have a "black" top, its a stock GT intake, the water passage just behind the alternator should be aluminum, if it's the 'newest' intake done by recall. Also, there is no way that you can have a cobra intake on stock heads,unless head swap was done as well, due to the intake having 16 ports versus the stock having only 8. And if you did have the cobra head swap done, the heads and valve covers would be massive, the DOHC Cobra engine is stuffed in that compartment..... get the pics...
green96gt is offline   Reply With Quote
Old 10-04-2004, 05:34 PM   #12
I think I might have run across what actually is different about my intake manifold. It seems like the guy i bought it from was just misinformed. When the recall took place (3 or 4 years after 1996) instead of putting on the same intake manifold, he put on a new one that had fixed the previous problem and refined some of the other parts on the intake to get more efficiency out of the part. So, next time I am home I will post pictures. Too bad it isn't the cobra mod, but heck this one is said to increase around 10-12 hp so I will take that. Thanks again guys.
Old 12-09-2004, 07:00 PM   #13
Send a message via AIM to Acer2428
To get 32v heads you also need a completely new wiring harness...
If you ahd the "PI" intake manifold it's supposed to add 30-35 hp w/ adapter plates from livernois and 15 or so without.
Acer2428 is offline   Reply With Quote
Old 01-03-2005, 06:05 PM   #14
I don't think it will fit.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 01-03-2005, 06:11 PM   #15
those year gts have issues with the lower intake messing up so thats probably what was fixed, with just a stock car they put down 215/285 bhp or 178/235 tq (with a manual... with auto MUCH lower numbers...)
they run 15.2s with a stock your probably in the 15.0 range now. with an auto .... 15.5 stock 15.3s now definatly get pictures of the motor.
Old 01-03-2005, 06:25 PM   #16
It is not worth it.
'99 Buick Regal GS (modded) FS A5295 Mustangs for Sale and Wanted 7 09-05-2009 10:27 PM
New CAI I modded today Foxone Pre-2005 V6 Mustang 10 02-15-2009 03:04 AM
what's faster, modded V6 or stock GT? I_luv_HP&trq The Bar 11 09-24-2005 07:50 PM
CBR or Modded v6? The Arson The Bar 11 05-06-2005 09:15 PM
BADASS VIDEO... 03 cobra vs modded fox body and modded SS... Zim The Bar 5 07-25-2003 12:54 AM
04:28 PM
